Pour gas milage, need help.
Old Aug 2, 2015 | 07:09 PM
ronsar's Avatar
ronsar
Default Pour gas milage, need help.
Okay so this winter I installed a stage 1 air cleaner and true duals, re-jetted the carb to a 180 jet, I'm running Screaming eagle plugs with 10mm wires which I had on last year at the end of the season. My mileage went down to 36 mpg from 40 to 45. I just installed Screaming eagle street cannon mufflers and added baffles to drop the sound levels to legal levels. Sounds great and plugs look good. I'm thinking of going back to stock air cleaner? anyone have any ideas.
Old Aug 2, 2015 | 08:07 PM
Joe_G's Avatar
Joe_G
Baffles will help, true duals aren't as efficient in our bikes as the stock 2 into 1, but it's better with baffles vs open pipes. See if that gives you back some mileage.
Air cleaner won't make much difference at all based on my research and comparative dyno sheets I found.
Old Aug 2, 2015 | 08:55 PM
Prot's Avatar
Prot
You may need to make a small adjustment to your carburetor since you made a change to the exhaust.
The screamin eagle air cleaner kit (not just a filter dropped into the stock air box) flows a lot more air than stock. I initially had a drop in filter and switched to the full kit and it really let it breathe a lot more and enhanced the other stuff I did to the engine.
The thing about mpg on these bikes is that once you unleash more power, you will unconsciously twist the throttle harder and faster which of course burns more fuel.
I was curious what cam are you running?
Old Aug 2, 2015 | 08:58 PM
ronsar's Avatar
ronsar
Stock cam, just had that and the oil pump and push rods done. The air cleaner is an Arlen Ness Stage 1
Old Aug 3, 2015 | 04:13 PM
tomfiii's Avatar
tomfiii
An evo comes jetted fine with stock main jet,it's usually the low speed jet and idle adjustment that must be changed.
Old Aug 3, 2015 | 04:15 PM
Dr.Hess's Avatar
Dr.Hess
Exactly what bike and what carb are we talking about here?
Old Aug 3, 2015 | 04:21 PM
ronsar's Avatar
ronsar
Default 93 evo
Bike is a 93 EVO Tour Glide, stock carb. main jet is stock and idle is a 180
Old Aug 4, 2015 | 05:43 AM
grbrown's Avatar
grbrown
Exclamation
A 180 jet is the main jet, not the idle jet, which is around a 45. Has the blank over the slow speed adjuster screw been removed, so you can adjust it?
Old Aug 4, 2015 | 06:37 AM
ronsar's Avatar
ronsar
Default Jets
Well that makes sense now, so I have the jets reversed. The 45 that it should be is actually a 42 that is in there now. Yes I installed an easy adjustment screw so I can fine tune the carb and have it not just a hair above popping upon acceleration and drop off.
Siber
Jun 12, 2021 10:54 AM
Rwillden
2014-2024 Touring Models
May 1, 2015 11:00 PM
Steel Steed
Jun 20, 2011 06:02 PM
primeaus883
Mar 20, 2008 10:24 AM
italiano
Feb 15, 2007 05:35 AM
