1987 FLHS Not Getting Gas
Old Aug 23, 2015 | 01:25 PM
Rick35's Avatar
Rick35
Stage I
Default 1987 FLHS Not Getting Gas
My 1987 FLHS after winter storage wants to run but isn't getting fuel. It has new gas and has always been bulletproof (I bought it new).
I can pump the throttle six or seven times and get a spray of gas going and she'll fire right up as always, but then she just dies. It's definitely a fuel issue. Don't know what's wrong. Maybe it's finally time for a CV carb rebuild. The '87 carb had the butterfly valve.
Gas petcock is turned ON
Any thoughts??
Rick35
Old Aug 23, 2015 | 01:30 PM
Beemervet's Avatar
Beemervet
Starting from the tank:
1) Pull the fuel line at the petcock, check flow.
2) Pull the fuel line from carb, check flow.
3) If those are ok, you may have clogged jets.
4) I agree, go to a CV carb. You'll like the difference.
Old Aug 23, 2015 | 02:42 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If no flow at #1 pull petcock and check strainer.
Old Aug 23, 2015 | 02:50 PM
Beemervet's Avatar
Beemervet
Thank you.
Old Aug 23, 2015 | 02:52 PM
Dr.Hess's Avatar
Dr.Hess
Sea Foam.
Old Aug 23, 2015 | 02:54 PM
texashillcountry
Dirt don't hurt
Originally Posted by Dr.Hess
Sea Foam.
Hey Traildog when did you hack Dr. Hess's account????????
Old Aug 23, 2015 | 03:02 PM
Beemervet's Avatar
Beemervet
Old Aug 23, 2015 | 05:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
First step: remove butterfly carb.
Step two: throw it into the scrap bin.
That old carb isn`t worth spending money on, time for a CV/Mikuni/S&S.....
Best bang for the buck upgrade I have done on my `89 (hell....best performance upgrade...period).
Old Aug 23, 2015 | 11:09 PM
Hackd's Avatar
Hackd
Originally Posted by Rick35
My 1987 FLHS after winter storage wants to run but isn't getting fuel. Any thoughts??
Since it's the 24th of August, and you're just taking your bike out of winter storage, I think it's time to move further south.
Sea Foam.
TD aside.... Try it. I'd run a full bottle of the stuff through the tank. Your carb is definitely gummed up. If that doesn't make an improvement, then start working through the check list that was posted.
You didn't happen to put some sort of fuel stabilizer in the tank before you put the bike up? Sta-Bil? The last time I used Sta-Bil, my bike did the same thing as yours. Started up, but would not stay running. Had to get the bike towed from the storage facility. The carb needed to be cleaned. Shop told me it looked like Jello had set up inside the bowl.
If you're thinking CV carb, good time as any to slap one one.
Ozark Joe
EVO
43
Dec 3, 2015 03:20 PM
lagrato53
Carburetor Related
Mar 13, 2014 06:31 AM
Hydro
Carburetor Related
Aug 8, 2012 12:27 AM
rc51ironhead
Ironhead
Jan 30, 2009 12:44 AM
petey420hawg
Sep 28, 2008 10:08 PM
