Totaly stumped on new engine issues/symptoms
Old Dec 1, 2015 | 02:41 AM
Ozark Joe's Avatar
Ozark Joe
Default Totaly stumped on new engine issues/symptoms
Today I took the bike out to a doctor appointment so I could conserve what little gas remains in my Buick. On the way back the bike cutout completely 3x like it ran out of gas but I know I had at least 2 gal remaining and it only 20 miles to the appointment. I restarted each time started fine but every time I got over 40mph it cut out. I finally manage to get home and park the bike. Then went to take an hour nap before work. (I have the stomach flu and was up all night Mon morning tending to the nasty stuff that goes with it.) About 30min into the nap my wife informed me that there was a large pool of gas under the bike. I went out side to check it out and couldn't figure out where it came from. So do you thing this is related to the Intake Manifold mentioned on my earlier post?
Old Dec 1, 2015 | 03:32 AM
Ron750's Avatar
Ron750
I couldn't find any earlier posts about a manifold. Where is that?
Old Dec 1, 2015 | 04:04 AM
Yankee Dog's Avatar
Yankee Dog
Float in carb is sticking from dirt or whatever is my guess.
Check your fuel line, when it gets old, it will start to crumble from the inside out and that junk has to go somewhere...right into your carb and float needle.
Not sure what issues your having with your intake, but fuel air mist is the only thing that should be going thru the manifold.
The puddle tells me the your float is sticking from either debris on the float needle and or seat allowing fuel to keep running into the carb and out the over flow.
Do you shut off the fuel at the petcock after a ride? YD
Old Dec 1, 2015 | 04:17 AM
grbrown's Avatar
grbrown
As YD suggests, the pool is caused by not turning off the gas tap, but the main culprit is likely to be a dirty fuel bowl in the carb. I suggest you get a carb overhaul kit, but also drain the tank and clean it and the gas tap, just in case there is some crud in there.
Old Dec 1, 2015 | 06:38 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
+1 for cleaning the carb and replacing the fuel line.
Old Dec 1, 2015 | 06:53 AM
traildog's Avatar
traildog
I'll second that opinion...............
Old Dec 1, 2015 | 08:05 AM
Owtlaw's Avatar
Owtlaw
And if you have a vacuum operated petcock, you can assume it's bad.
Old Dec 1, 2015 | 08:21 AM
johnjzjz's Avatar
johnjzjz
my guess is the ignition trigger in the cone has been over heated and or the new one is bad - when it gets hot it cuts out - wait a couple mins and it starts back up and runs for 10 more
Old Dec 1, 2015 | 08:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
For the fuel issue, yea a rebuild. Make sure your kit has a brass needle and seat for the float the aluminum ones suck...
Old Dec 1, 2015 | 08:52 AM
texashillcountry
Dirt don't hurt
The way I read the original post the bike would stay running until he got over 40mph.
Would that also indicate a failing ignition trigger?
I thought when they failed it was because of heat not speed.
