Thinking of doing some engine modifications to my 98 FLHR during the off-season. It has about 32k miles. Any suggestions or ideas where I would bet the most bang for the buck...things to stay away from? Thanks
Our Evos have several adaptations to help them meet noise and emissions requirements, which include lean carb settings, mild cams, quiet airbox and mufflers, but the part that is often over-looked is the retarded advance curve in the ignition system.
Here are part numbers and prices from a couple of years ago on my 95 Heritage Softail Classic. I absolutely love it. It pulls from idle on up, runs smoother than it ever has, and runs substantially cooler.
Here you go.
Andrews EV-13 cam $119.95
Dynojet Thunderslide with Jet Kit 8708 $128.42
Crane Cams Time Saver Adjustable Push Rods 4-0030 $126.72
Dynatek 2000P DD2000-HD2EP ignition module $145
Crane Cams big axle lifters 3-2050. set of four for $189.95
Crane Cams cam bearing 7-0400 $15.51
Cometic Cam Gasket Service Kit C9624F $19.04
Cometic EST Top End Gasket Kit w/.030" Head $87.39
Screaming Eagle Air Cleaner Kit (Carbureted Evo) 295433-99B $127.96
New set of stock rings
Not to be a pirate !!! But.... Ev 13 recommend for his bike, ev 27 for mine , is that due to size/weight of the two bikes ?
They are both great cams. I had an EV27 in my Glide for several years, but that was the 'wisdom' of the time. A great improvement over stock. The EV13 is said to be a bagger cam, the EV27 for other models, but I suspect the EV27 is the most popular across the range.
