Its a James gasket. I sorta ordered it by mistake. With this gasket, the derby sticks out a little bit. No big deal if as long as its OK to use. Seems like a good gasket that can be re-used a few times.
AFM isn't a brand it is a type of gasket.
AFM stands for aluminum foam matt.
Basically it is a piece of aluminum with foam on both sides.
AFM gaskets can be reused several times before they wear out.
I love these gaskets. I think my cam case and trans gaskets are this material as I successfully reused both. So much nicer than scraping like old gaskets.
