Turn Signals
Old Dec 6, 2015 | 11:38 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Dr.Hess
Check the bulbs.
When a bulb burns out, it changes the resistance and the turn signals don't blink correctly.
Old Dec 6, 2015 | 06:35 PM
14GuineaPig's Avatar
14GuineaPig
Here's the info for recall 92V-173. It's got to do with the needle valve in the fuel inlet of the carb.
available for this search.) Filtering Results... UPDATING VIEW...
RECALL Subject : FUEL:FUEL SYSTEMS , 1 INVESTIGATION(S)
Report Receipt Date: NOV 30, 1992
NHTSA Campaign Number: 92V173000
Component(s): FUEL SYSTEM, GASOLINE
Potential Number of Units Affected: 66,046
All Products Associated with this Recall
Vehicle MakeModelModel Year(s)
  • HARLEY-DAVIDSONFL1990-1991
  • HARLEY-DAVIDSONFX1990-1991
  • HARLEY-DAVIDSONFXD1990-1991
  • HARLEY-DAVIDSONFXR1990-1991
Details
1 Associated Document
Manufacturer: HARLEY-DAVIDSON MOTOR CO.
SUMMARY:
THE FUEL INLET NEEDLE DOES NOT SEAL PROPERLY AGAINST THE FUEL INLET SEAT. CONSEQUENCE:
THE FUEL OVERFLOW SYSTEM ALLOWS FUEL TO LEAK ONTO THEGROUND, WHICH COULD RESULT IN A FIRE IF EXPOSED TO A SOURCE OF IGNITION. REMEDY:
REPLACE THE FUEL INLET NEEDLE. NOTES:
SYSTEM: FUEL.VEHICLE DESCRIPTION: HEAVY MOTORCYCLE.
Request Research
Select this checkbox to order available documentation for a fee. Submit using the form that will appear below.
Loading...
NameDescriptionSize(KB)RC-92V173-NN.PDFRecall Document141
Old Dec 6, 2015 | 06:37 PM
14GuineaPig
This is the info for recall 91V-001
Make : HARLEY DAVIDSON
Model : HARLEY DAVIDSON
Year : 1991
Manufacturer : HARLEY-DAVIDSON MOTOR CO.
NHTSA CAMPAIGN ID Number : 91V001000
Mfr's Report Date : DEC 07, 1990
Component: EXTERIOR LIGHTING:TURN SIGNAL:SWITCH
Potential Number Of Units Affected : 19950
Summary:
TURN SIGNAL CONTROL MODULES MAY CONTINUE TO FLASH IN THE PRESENCE OF A NON-FUNCTIONING TURN SIGNAL LAMP WHICH IS NONCONFORMANCE TO FMVSS 108.
Consequence:
DRIVER WOULD NOT BE AWARE THAT TURN SIGNAL LAMP IS NOT FLASHING. OTHER DRIVERS WOULD NOT BE WARNED WHEN THE MOTORCYCLE WAS CHANGING LANES OR MAKING A TURN, AND COULD RESULT IN AN ACCIDENT.
Remedy:
REPLACE TURN SIGNAL CONTROL MODULE, AS NECESSARY.
Recalls Documents
RC-91V001-NN.PDF (http://nhthqnwws111.odi.nhtsa.dot.go...-91V001-NN.PDF) Recall Document
Old Dec 7, 2015 | 07:22 AM
Schex's Avatar
Schex
If it hasn't been a problem in the last 25 years, it probably isn't going to be a problem for the next 25.
And that's why it's still an open recall on mine.
Old Dec 7, 2015 | 05:33 PM
traildog's Avatar
traildog
Listen to these guys. They know their stuff....
Old Dec 9, 2015 | 11:19 AM
bigpappa160's Avatar
bigpappa160
I gotcha I am listening and I very much appreciate all the information. I was suppose to take bike in the get the fuel needle recall seen about, but it would start, it had lights and everything, but battery wouldn't turn over motor enough to fire up the motor but had enough juice to run the neutral light and oil light and all the accessories. But I called my son to bring jumper cables to help jump it off well I hooked up cables and nothing and now now lights come on. Took batt out to it to harley shop and it was completely dead, so bought a new batt. I'm at work so tonight I'll be putting new batt in bike.
Old Dec 9, 2015 | 12:45 PM
Dr.Hess's Avatar
Dr.Hess
And go through the sticky.
DBLX
Jan 28, 2016 06:24 PM
LarryMcDermott
May 9, 2014 06:17 AM
DirtyPak
Sep 6, 2011 11:00 AM
z28kilr
Apr 16, 2010 11:58 AM
matthew101376
Jul 5, 2009 03:57 PM
