Starter Problems
Old Feb 19, 2016 | 12:18 PM
JRH24's Avatar
JRH24
2nd Gear
Default Starter Problems
After discovering a clogged fuel filter, a jump start and the bike fires up. Rides fine. No problems. The next day I get a weak attempt at a start and then the starter just clicks like the battery is dead. Had the battery tested. Shows a good charge.
Thoughts on the problem? Probably electrical? I have no idea
1997 Heritage Softail Classic. S&S carb. Everything else stock.
Old Feb 19, 2016 | 12:23 PM
Ruggs59's Avatar
Ruggs59
Check your battery cables on both ends and make sure they are clean and tight.
Old Feb 19, 2016 | 01:38 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
How old is the battery?
Did you just check voltage or did you load test the battery?
Old Feb 19, 2016 | 01:52 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Feb 20, 2016 | 07:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t buy a starter...
Have the battery load tested.
Disconnect and clean both ends of the battery cables, the terminals on the battery and starter and also where the ground cable attaches to the frame.
If this does not help, don`t panic, don`t buy a starter...you may just have to replace the electrical contacts in the solenoid (simple and cheap).
Streetrunner
Apr 9, 2024 12:08 AM
cmosentine
Sep 25, 2013 12:32 AM
ae4782tt
Exhaust System Topics
Oct 4, 2010 12:39 AM
alymeg96
May 1, 2010 11:47 PM
alymeg96
Mar 30, 2009 08:45 PM
