Intake Options?
Old Mar 16, 2016 | 12:59 PM
johnjzjz's Avatar
johnjzjz
some of the air filters take power away harleys air filter is called a still air box and stock it works as should if you add mods then modding the still air box is needed like spanners has said
Old Mar 17, 2016 | 07:45 AM
RGranville's Avatar
RGranville
Originally Posted by 0maha
...From what I can tell, the MoCo has discontinued the required Screamin Eagle part. Is it worth trying to track one down anyway?
Custom Chrome/Revtech sells a product that is nearly identical to the SE air cleaner kit. I found one at a swap meet for $20 and put it on my 1990 FLHS. Though I have high-flow SE mufflers, and this air cleaner is designed for more air flow, I'm not completely convinced there are any noticeable gains in using this air cleaner setup. The bike is otherwise stock. I almost feel the bike ran better with the stock airbox unmodified, and am considering going back to the stock airbox, modified as Omaha did to see what my 'butt-dyno' tells me.
For anyone interested, the Revtech part does appear in the 2015 CC catalog at http://www.customchrome.com/catalog/...l.asp?page=409
Old Mar 17, 2016 | 07:21 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Truly K&N's are not cheap but they do flow....
Old Mar 18, 2016 | 09:01 AM
TPost's Avatar
TPost
Did you rejet your carb after changing you mufflers and drilling out your backing plate?
Thanks, Todd
Old Mar 18, 2016 | 09:22 AM
0maha's Avatar
0maha
Thanks, Todd
Actually, I did it before. Plugs seemed lean when I first pulled them last year when I got the bike, so I rejetted richer. When I re-checked the plugs, it looked like I over-did it.
I'm feeling like it's pretty close. My indy next door has a dyno. I may run it over there and get an actual measurement and see what's up.
Old Mar 19, 2016 | 01:48 AM
Spanners39's Avatar
Spanners39
I ran a cheap K&N imitation for 6 months....now I run the real thing....guess why?
Old Mar 19, 2016 | 06:51 AM
98hotrodfatboy
It deteriorated and got sucked in, For 500 Alex.....
Old Mar 19, 2016 | 08:05 AM
johnjzjz's Avatar
johnjzjz
because the Dutch are Cheap bunch ?????????????????
Old Mar 19, 2016 | 09:27 AM
1997bagger's Avatar
1997bagger
You where saving money to buy your favorite sheep a new bow?
Bluesrider.df
Aug 15, 2017 10:27 PM
dn.bnntt
2014-2024 Touring Models
Feb 28, 2016 01:23 PM
Sharkman73
Nov 3, 2013 12:45 PM
Comingapart
Mar 1, 2011 03:26 AM
Kski
Jun 10, 2008 11:04 PM
