Worn and wiggly shifter
Old Apr 12, 2016 | 10:39 AM
richard567's Avatar
richard567
the shaft and its bushings can be found on ebay...did my 89 flhtc...
Old Apr 12, 2016 | 01:23 PM
falconbrother's Avatar
falconbrother
Mine has that issue, shifter shaft wobbles in the hole that runs through the front of the primary. The older EVOs don't have a replaceable bushing there. Maybe the newer one's do? I have a 1988 and it rattles like crazy. I'm sure it's bad for things downstream to be getting the micro jackhammer treatment all the time. Whatev's..
Old Apr 12, 2016 | 03:54 PM
grbrown's Avatar
grbrown
Wink
Originally Posted by Dazzauk
actually had a thought it could either be a worn shifter shaft or the hole in the footrest support could be worn and enlarged or a combination of both dam!!
I've just replaced the bushings and shifter shaft on my Glide, which has improved things greatly. I have previously replaced the shifter rod with a more modern s/s one, which has ball-ends, which also helped.
Old Apr 12, 2016 | 06:12 PM
glidein wide's Avatar
glidein wide
Use a mirror and look under the shifter where the steel spines are, mine has a set screw that can be snugged up occasionally, it's only about an 1/8" . Mine is aftermarket though, bronze bushing to the right of it.
Old Apr 13, 2016 | 08:05 AM
DeputyLoud's Avatar
DeputyLoud
In my case it was indeed worn teeth on the spline of both the shaft and levers. I ordered all new parts from Ronnies Harley Davidson online at a discounted cost for about $100. New shaft, levers, pegs and all bushings needed for a complete rebuild. Problem solved for another 25 years.
Old Apr 13, 2016 | 07:31 PM
glidein wide
Highly recommended...
213_LooseNoodle
Sep 3, 2019 03:20 PM
olyc
Aug 1, 2018 09:10 PM
prplglide
Jul 12, 2015 08:13 PM
1stHD_95FXDWG
Feb 27, 2014 09:49 AM
gotbik95
Jun 14, 2010 11:05 PM
