Is there a bush that goes on inside the foot peg where the shift shaft is?
Can't find a part number?
Thanks
I think if the part number is not in the online manual then it's discontinued.
That's one of the downsides to an online manual.
You can go to your local dealership and look at their paper parts book to get the part number then your dealer can do a search to see if any other dealers have the part in inventory or if the part is available from vintage parts.
With the part number the dealer can cross reference aftermarket catalogs and see if it is available in one of them.
I guess the shaft goes through the footpeg and could be worn smaller than once was??
If your foot shifter is wobbling around on your shifter shaft and tightening up the bolt doesn't work then the teeth are worn.
You can either get new parts or you can take a small piece of a beer/soda can and put it in between the foot shifter and the shifter shaft.
The second is only a temp fix but it does work for a while.
