84 triple trees help
Old Sep 16, 2016 | 04:13 PM
perpulreaper's Avatar
perpulreaper
Default 84 triple trees help
Been a wile sense I've been here been hanging over at the sportster forum wile I was building my hardtail ironhead
Anyway I'm in the middle of making my 84 flhtc into a trike and have run into a snag
Can't find any raked triple trees that say they will work with my bike found some that go back to 87 but most only go to 97
I do see an adjustable set that say 83 to 84 but I know the early 84's where shovel head with a 4 speed and my late is an evo with a 5 speed had to ship a swingarm back because of the difference but figure that may just be because of the two direct trany
Any one here able to tell me if the triple trees changed withe the motor change
Old Sep 17, 2016 | 05:35 AM
grbrown's Avatar
grbrown
Jolly good question. With your bike you are on the cusp between shovel and Evo eras, with many early parts carrying over. Use one of the on-line parts websites to check part numbers. Your '84 seems to have '#45431-79B, FORK STEM AND BRACKET', same as a late shovel.
Old Sep 17, 2016 | 06:44 AM
perpulreaper
Thank you Graham
That's what I suspected
Old Sep 17, 2016 | 07:08 AM
perpulreaper
Thanks for the parts finder that helps alot
Old Sep 17, 2016 | 09:03 AM
Tom84FXST's Avatar
Tom84FXST
4 speed trees will not work...FLHT's have touring "backward" trees.
Any of the newer touring trees will bolt on and work as far as the suspension goes...but they will not work with the ignition switch and fork lock ...but can be made to work with heavy modification.
I am running a 83 lower tree with a 97 top tree in order to run a newer fairing.
Old Sep 18, 2016 | 08:01 PM
perpulreaper
So are you saying the trees I see for the 87 will work with my 84
Old Sep 20, 2016 | 05:21 AM
Tom84FXST's Avatar
Tom84FXST
98hotrodfatboy
Shovelhead
23
Mar 4, 2018 07:13 PM
FXD_One
EVO
Nov 3, 2011 04:33 PM
10Seconds
EVO
May 2, 2011 05:29 AM
sunup420
EVO
Sep 3, 2009 07:23 PM
werewolph
EVO
Feb 1, 2009 12:28 PM
