Hit a pothole that damaged the fender.
Old Nov 17, 2016 | 11:36 PM
Ozark Joe's Avatar
Ozark Joe
Default Hit a pothole that damaged the fender.
I was going down a back road when a pothole came out of nowhere. I then ran over it not realizing how deep it really was. Scared the hell out of me. I almost was expecting to go down but it never happened.Luckily it only warped the fender. So it rubbing on one side. That leaves me shaking my head on how to warp it back in to place without scratching the paint or putting any more dents in it.
Old Nov 18, 2016 | 12:05 AM
Prot's Avatar
Prot
Pictures might help.Was it the front or rear?
Old Nov 18, 2016 | 12:58 AM
Ozark Joe's Avatar
Ozark Joe
I'll have the fender off but it's the front fender.
Old Nov 18, 2016 | 01:10 AM
Prot's Avatar
Prot
Was it one of those extended fenders that wrap around the wheel and sit very close to the ground? Otherwise I can't imagine a hole deep enough to damage a fender.
You should check the front wheel. If it was that big of a hole, you may have bent the wheel or possibly damaged the tire.
Old Nov 18, 2016 | 05:12 AM
Tom84FXST's Avatar
Tom84FXST
If the front has been lowered, the fender can hit the bottom triple tree
Old Nov 18, 2016 | 05:51 AM
Crashone's Avatar
Crashone
As Prot says check the wheel. Look for dents in the rim especially if it is a spoked wheel. Try to get it in the air and spin it and see if it wobbles.
Also check the rear rim for the same kind of damage, it rolled through it too.
Old Nov 18, 2016 | 07:32 AM
Uncle G.'s Avatar
Uncle G.
I thought we had a monopoly on potholes here in NY.
Old Nov 18, 2016 | 05:15 PM
rizzo's Avatar
rizzo
Don't take it off yet. I had mine tweaked when the tire went flat in a drive in chock. I got it in the air and used a pair of wooden dowels pushed up under between the tire and fender from the bottom end and used them as levers to pry and move the fender while it's still attached the the lower legs, it will be much easier to get it aligned with the tire. If the dents are on the sides I've had success using various sizes of C clamps to flatten and straighten them.
Old Nov 18, 2016 | 05:37 PM
aces&8s's Avatar
aces&8s
You hit a Obama shovel read job holes that never were fixed because of the lining of the pockets got in the way.
Old Nov 18, 2016 | 06:50 PM
Beemervet's Avatar
Beemervet
