1986 tourglide wiring
Old Nov 24, 2016 | 09:05 PM
Rowansdad's Avatar
Rowansdad
Default 1986 tourglide wiring
I recently purchased a 1986 fltc. It looks good but has some covered up issues. The main issue isn't the fault of the bike, it's the fault of the previous owner and their love for crimp connectors and lack of wiring knowledge. I started to pull the motor off as it's cold here now and want to freshen the motor up and paint the frame so I'll be ready to ride this spring. Once I got into the fairing for removal I quickly realized the wiring had been hacked up. So now I am looking for diagram so I can make up a new harness with things like solder and heatshrink tubing.
Old Dec 4, 2016 | 12:25 AM
mkguitar's Avatar
mkguitar
a little messy indeed.
but if you look at any OEM wiring harness on any vehicle- you will see that it is all crimp connectors.
soldered joints break due to vibration- usually right where the tinning ends the wire strands will flex and break one by one.
the shrink will help to hide the breaks and contribute to a double handful of intermittent problems, as the strands break resistance will build and fuses may blow here and there due to the extra load.
I found out the hard way a long time ago.
Mike
Old Dec 4, 2016 | 04:29 AM
Schex's Avatar
Schex
This may be an option, look through this thread, he converted to a later model wiring harness.
You may pick up on some other ideas using later model stock parts on your build.
https://www.hdforums.com/forum/shove...ure-heavy.html
Old Dec 4, 2016 | 05:32 AM
smitty901's Avatar
smitty901
Good luck with the project. As a RGU rider I have long been a fan of the Tour Glide /RG.
Will be looking forward to seeing your project come along.
Old Dec 4, 2016 | 08:56 AM
rivercityslim's Avatar
rivercityslim
Two words: Factory Manual.
Old Dec 4, 2016 | 09:20 AM
14GuineaPig's Avatar
14GuineaPig
You can try here for a wiring diagram. It takes a while to download. If you use Google Chrome, then by using the print button, you can save it as a PDF file.
https://serviceinfo.harley-davidson....5526&groupId=9
Old Dec 4, 2016 | 01:13 PM
Tom84FXST's Avatar
Tom84FXST
Mid 80's wiring harnesses weren't that great when they were new...after 30 years they are not worth trying to fix.
My method for repairing these old wiring harnesses is simple...
  1. remove old harness
  2. put in trashcan
  3. install new aftermarket harness
I have installed many of these ultima harnesses with 0 problems...will be installing another in the next few weeks. All the wires are clearly marked, a child could install it. Has self canceling turn signals, 4 way flashers, and different brake light options.
http://www.ebay.com/itm/COMPACT-ELEC...9Tsfs9&vxp=mtr
One I installed:
https://www.hdforums.com/forum/softa...kend-pics.html
Old Dec 4, 2016 | 02:16 PM
Rowansdad's Avatar
Rowansdad
  2. put in trashcan
One I installed:
ok there is no point in even buying the wire and connectors when you can buy a complete assembly with light and turns for 140 bucks. Does it come with the starter circuit and all the wire for ignition module and what not?
wild_one
EVO
Mar 25, 2015 07:19 PM
pp6000v2
Mar 1, 2015 04:44 PM
texashillcountry
EVO
17
Nov 24, 2014 04:22 PM
steiniger
Sep 4, 2009 01:07 AM
DJJSR
Custom Models
Jun 11, 2006 10:03 PM
