Throttle not snapping back
Old Feb 13, 2017 | 11:24 PM
NightRiderr's Avatar
NightRiderr
6th Gear
Default Throttle not snapping back
Yes yes I know this has briefly been covered lately although my situation is a tad different.
Im trying to install new avon grips on a 1993 FXRS-SP and as everything was on, I go to twist the throttle and it twists back fine but doesn't snap back. I've tried adjusting the cables that doesn't work. I also didn't get any new bars. The same bars were snapping the throttle back easy, and these new grips don't.
Would it have something to do with the switch housing clamping too tight around these avon grips?
Any ideas or suggestions helps me out thanks.
Old Feb 14, 2017 | 06:39 AM
misfitJason's Avatar
misfitJason
When you install new grips (especially the throttle side) you want to leave a tiny gap between the end of the bar and the end of the throttle sleeve or they will bind. Loosen everything and slide it a little bit to your right if you were sitting on the bike
Old Feb 14, 2017 | 07:02 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Check to make sure your thumblock isn't partially engaged.
Old Feb 14, 2017 | 08:09 AM
RK_Classic's Avatar
RK_Classic
THIS....
rk classic
Old Feb 14, 2017 | 09:46 AM
misfitJason
Excellent point
Old Feb 15, 2017 | 07:42 PM
texashillcountry
Dirt don't hurt
Did you get your problem fixed?
Old Feb 15, 2017 | 08:30 PM
RedHogz's Avatar
RedHogz
Sounds like the OP jammed the throttle sleeve perty tight. Aligning everything is a PITA.
Old Feb 17, 2017 | 08:09 PM
johnod's Avatar
johnod
What thumb lock?
Old Feb 17, 2017 | 08:32 PM
texashillcountry
Dirt don't hurt
Originally Posted by johnod
What thumb lock?
It's on the right side turn signal housing right next to where the throttle cables go into the housing.
Also known as a throttle lock.
GlennB.
Nov 6, 2011 04:25 PM
tacoma5432
May 25, 2011 07:40 PM
RocketRocker
Dec 15, 2009 11:42 AM
loseranacummins
Apr 19, 2009 09:59 PM
1.4G
Aug 8, 2008 01:25 PM
