Loose Head Bolt
Old Feb 27, 2017 | 07:12 AM
Hackd's Avatar
Hackd
Originally Posted by 0maha
I'd be suspicious of that insert.
To do anything else might be good thrown after bad.......
IIRC, the head bolts are 'torque to yield'. Tighten in sequence to spec, then 1/4 turn????
Old Feb 27, 2017 | 07:40 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That depends on whether you use OEM or aftermarket gaskets.
Aftermarket gaskets are torqued in steps up to 42 ft lbs and OEM gaskets are torqued to 7 ft lbs then turned a 1/4 turn.
Old Feb 27, 2017 | 11:28 AM
johnod's Avatar
johnod
Update.
A pulled stud is the problem, none of them on that cyl seem to have thread inserts, certainly not the one that pulled.
So any more advice?
Can an insert be installed with engine in place, (I hope)?
Is a new stud required?
Any info is helpful.
I've already removed head and cyl.
Thanks
Old Feb 27, 2017 | 11:47 AM
Dr.Hess's Avatar
Dr.Hess
While I have not had to deal with this problem (knock on wood), most people have repaired this without pulling the motor further apart. Timesert or Helicoil it and go. Some of the usual tricks like using a vacuum, lots of grease when you do it would help keep the crud out of the bottom end. Your original stud should also be OK to reuse.
Old Feb 27, 2017 | 11:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Yes it can be repaired but you might have to pull the case and bring it to reputable machine shop familiar with Harley case repairs..
Old Feb 27, 2017 | 12:03 PM
flhchaz's Avatar
flhchaz
Sorry to hear about this John. Good luck.
Old Feb 27, 2017 | 12:21 PM
johnod's Avatar
johnod
Thanks Chaz, it'll allow time for those other parts to come in.
Crueltiming
Engine Mechanical Topics
11
May 13, 2019 06:03 AM
owenewowen
Jan 25, 2019 03:29 PM
kino44
EVO
Jul 1, 2014 02:47 AM
95 Ultra
EVO
Nov 3, 2012 05:57 AM
BigJim8765
Exhaust System Topics
13
Feb 8, 2010 12:20 PM
