forward controls 06 Dyna
Old Mar 2, 2017 | 04:15 PM
abed642's Avatar
abed642
Stage II
Default forward controls 06 Dyna
going to install forward controls on my 06 Street bob. I've read several articles stating that the inner and outer primary covers will fit together and create a "tunnel" hole that will not leak. I've read others that state some newer models don't create the tunnel and will leak. I'm not sure what is considered "newer" and was wondering if anybody could tell me if I need an actual plug to prevent leaking, or can I just install something cosmetic to hide the hole. any insight would be great!!
Old Mar 2, 2017 | 04:35 PM
flhchaz's Avatar
flhchaz
You may want to check in with the Dyna section for HD Forums. You'll probably get a better response from those guys.
Old Mar 2, 2017 | 04:40 PM
RedHogz's Avatar
RedHogz
Wtf is a 'Tunnel Hole'? If you're referring to the shift rod hole in the chain adjuster inspection cover, then it's an easy swap to a solid cover IF removable. If not, then leave the rod hanging out of the primary and simply connect the shift shaft to the forward control lever.
Old Mar 2, 2017 | 04:59 PM
brad75raiders's Avatar
brad75raiders
I had one for 10 yrs. No leaks.
Robbie13
Feb 25, 2012 02:08 PM
HarleyBobber
May 10, 2010 03:01 PM
itznin
Aug 31, 2006 01:37 AM
fireball
Apr 7, 2006 08:04 PM
BeavisRules
Feb 9, 2006 11:42 PM
