HI-4N guestion
Old Mar 29, 2017 | 12:35 PM
row jimmie's Avatar
row jimmie
Default HI-4N guestion
Has anyone put this ignition on and used factory duel fire coil. It has a application in manual, but wonder how it works. 1996 80 inch.
Old Mar 29, 2017 | 03:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Most guys use Ultima or Dyna. The crane is ok. But not sure if it's dual fire compatible. I here their coils are junk. The Ultima is great with your OEM dual fire coil.. set to curve 2... I use a Dyna 2ki.
Old Mar 29, 2017 | 03:37 PM
daven9113's Avatar
daven9113
I don't run this, but it will work. I'm not sure how many would bother fabricating a place for the second dual coil though. You should get the Crane coil, unless you don't have the money or don't want to. A stock dual coil is cheaper and easier to find.
Here's a relative cheap solution: http://www.jpcycles.com/product/382-...FYNofgodAfcK7Q
Here's the upside for having two dual coils. If your Hi-4 Crane craps out on the road, you can pack your stock ignition and run it off one of the dual coils.
Old Mar 31, 2017 | 12:56 PM
KozmoSoftail98's Avatar
KozmoSoftail98
I installed it last year and am using the stock Harley coil on a 98 FXSTC. It is fantastic. I recommend it.
Old Apr 2, 2017 | 01:56 PM
row jimmie's Avatar
row jimmie
[U
Thanks Kozmo,get gasket and cam seal soon. And im polishing cam cover.
Mzharleyhoney
Apr 11, 2016 02:11 PM
jfsgb
Shovelhead
May 10, 2012 11:59 AM
t150vej
EVO
13
Jan 27, 2010 04:00 PM
mjaw
EVO
Oct 23, 2009 03:07 PM
waynemags
EVO
May 28, 2009 02:41 PM
