Brake time
Old Apr 2, 2017 | 08:36 PM
98hotrodfatboy's Avatar
98hotrodfatboy
For the caliper you should use a ball hone to clean it up.... nothing works better...
Old Apr 3, 2017 | 08:25 AM
Hackd's Avatar
Hackd
Originally Posted by Yankee Dog
Watch that aluminum rivet thingy on the pad holder (sorry on my phone away from the parts diagram)... it can get bent if things are not put together exactly right even though it looks like it's correct, double check.
Yes to this ^^^^
The brake pad bracket is available if you trash the pin, but I don't show a part number for the slide bushing in my FPM. The rubber boot for that bushing is available, but as far as I see not the actual bushing. Which is telling me, you've got to order a new caliper to get it.
Old Apr 3, 2017 | 08:27 AM
br549A1's Avatar
br549A1
On front or rear? I'm not sure what you're taking about I'm looking at the parts diagram now.
Old Apr 3, 2017 | 09:33 AM
Hackd's Avatar
Hackd
Originally Posted by kp877
On front or rear?
Front. I'm not certain about the 98 models, but my 93-94 parts book shows the bracket part number 44072-92 for the left and 44073-92 for the right.
The pin (bushing) boot is part number 44054-83. But there is no part number or reference to the pin itself. What Harley calls a pin, is where the upper caliper bolt attaches through. The pin is meant to slide on the caliper, so it does need to be lubricated.
On the bracket, where the moving brake pad goes (and has an anti rattle clip), there is a small stud with a head on it that fits into the serrations on the head of the pin. You need to ensure that it is located correctly before you tighten the caliper back down, or you will bend either the stud or the pin's flanged head. (personal experience....)
Old Apr 3, 2017 | 12:30 PM
br549A1's Avatar
br549A1
Looks like 93/98 is slightly different but I think I know what you mean now I'll have to look at it again. Went to get the 6 orings and 6 sealing washers. Dealership didn't have and wouldn't order, refused to order! Went to Indy and they bent over backwards to help and found everything I needed and even sent me home with two pin boots just in case. They've come through for me before I they really went out of their way today and didn't have to at all.
Old Apr 3, 2017 | 08:56 PM
br549A1's Avatar
br549A1
Is this clean enough or do they need to be polished like chrome?
Old Apr 3, 2017 | 09:04 PM
Yankee Dog's Avatar
Yankee Dog
Looks good, but how do they feel? Should be smooth with no defects or crud seen or felt. YD
Old Apr 3, 2017 | 09:19 PM
br549A1's Avatar
br549A1
They are smooth they just aren't chrome smooth. One tiny knick on the rear and one on one front. I saw a bunch of them today at the store and none were smooth like chrome they all had the dull finish.
Old Apr 3, 2017 | 10:54 PM
Hackd's Avatar
Hackd
They look good, but does one have a pit in it?
The ones that were used to rebuild my front calipers had a chrome finish. But they were probably aftermarket, not OEM.
Old Apr 4, 2017 | 04:32 AM
br549A1's Avatar
br549A1
These are performance machine. They are all stamped with the logo. I don't have any polishing compound but I tried mothers metal polish and that's as clean as they'd get. I can pick some compound and a new wheel up if I need to
Wondering now how I know if these are even the right piston size. I can't even find a PM replacement piston for stock calipers. Anyone got a front and rear piston lying around for 84-99?
Attached Thumbnails Brake time-photo138.jpg   Brake time-photo441.jpg   Brake time-photo757.jpg
