These are performance machine. They are all stamped with the logo. I don't have any polishing compound but I tried mothers metal polish and that's as clean as they'd get. I can pick some compound and a new wheel up if I need to
Wondering now how I know if these are even the right piston size. I can't even find a PM replacement piston for stock calipers. Anyone got a front and rear piston lying around for 84-99?
I may have the front.
I'll check when it gets light out.
Thanks, I will search a little more but while they are apart I think I should make sure. I found a bunch of pm pistons on jp but none were 1-11/16 or close or I'm missing it.
Can you just measure the diameter of the piston? Approx is good don't think you need to pull it apart. Mine is 1-11/16" just want to make sure these pistons are correct since I can't locate a single PM piston for OEM calipers.
The calipers I have are OEM.
I'll send you the whole caliper for cost of shipping if you need it.
I don't need it. Just need to make sure the pistons I have in my front OEM calipers are the correct size. I can't locate and specs for OEM piston diameter.
When I get back outside I'll take apart the caliper to get the piston out and measure the OD.
Give me a while as I threw my back out a week ago and still dealing with it.
