Head Breather ?
Old Jun 9, 2017 | 01:50 PM
  #31
aces&8s's Avatar
aces&8s
Originally Posted by IBDAGRIZ
Yours may or may not look like this depending on year of production.
From S&S site:
S&S cases for 1984-'99 big twin engines, give the engine builder the option
of venting the crankcase breather from a fitting on the crankcase, through
the cylinder heads, or both. We recommend using both crankcase breathers
in engines of 96” or larger displacement. To make this possible in all
applications, there are two crankcase breather holes available in the rear of
alternator crankcases for 1984-’99 models. One is in the stock location, and
the other is angled down to allow the installation of a crankcase breather
fitting in chassis with integral transmission/oil tank.
My 96 is too close to the tranny on the dresser to run both, but the 113" works perfectly with both on it. Go figure.
Griz
That picture leaves a lot to be desired. Thanks.
Old Jun 9, 2017 | 01:53 PM
  #32
IBDAGRIZ's Avatar
IBDAGRIZ
LMAO!! Could be better for sure.
That's the oil pump location to the right of the two holes so it is kind of a pain to see installed.
Try this link.
https://www.sscycle.com/tech-info/in...eets/lower-end
Third choice from top (106-5058). Go to page 5, picture 6 and yours will be hole "E".
Griz
Old Jun 9, 2017 | 01:59 PM
  #33
grbrown's Avatar
grbrown
Red face
Originally Posted by aces&8s
Its been raining here a lot and I do still work so I ride ever chance I get.
The problem has been stated where S&S says anything over 96" needs to be vented from heads and crank case. I am not finding my crankcase vent yet, if it exist.
You have an S&S engine built and sold by them? Just ride and enjoy, there's a good chap. If you had scratch built it from a jumble of parts that advice would be useful to know, but you have one of the finest engines on the planet. I've no idea what breathers mine has.......
Old Jun 9, 2017 | 03:10 PM
  #34
aces&8s's Avatar
aces&8s
Try this link.
Griz
Thanks Griz, I looked on my engine and I don't have that crank vent port. Guess because my engine is brand new model.
Old Jun 9, 2017 | 03:13 PM
  #35
IBDAGRIZ's Avatar
IBDAGRIZ
That's odd since they suggest running both. Might give 'em a call and give them the engine numbers to verify.. I irritate them often enough and they still help out.. LOL..
Griz
Old Jun 9, 2017 | 03:14 PM
  #36
aces&8s's Avatar
aces&8s
Thanks Mr B, Your prolly right just ride it, But over here we are good lads on every other fortnight
Old Jun 10, 2017 | 04:33 AM
  #37
grbrown's Avatar
grbrown
Red face
Did you get an S&S service manual with yours? I've looked through mine, for the 3 5/8" and 4" bore engines (up to 113"), but haven't come across anything relating to the breather system, otherwise I could have been more helpful. Mine is a crate engine, complete with IST ignition, carb, ACRs etc.
You chaps are a bad influence to me most days......
Old Jun 10, 2017 | 07:00 AM
  #38
98hotrodfatboy's Avatar
98hotrodfatboy
If it truly needed the bottom case breather they would have installed at the factory..... However if you really need it, it should be at the rear of the case to the left of the oil pump. Page 4 of the following link shows it's location....
http://assetcloud02.roccommerce.net/...ers_manual.pdf
Old Jun 10, 2017 | 07:02 AM
  #39
aces&8s's Avatar
aces&8s
Yes I got the engine manual and it shows the oil pump with the vent ports to the left of it, but I don't see the crank vent ports on my engine.
Went for evening ride last night on an open hwy. Did a couple runs up to 5k, Quite happy with the launches.
Old Jun 10, 2017 | 07:04 AM
  #40
98hotrodfatboy
That's odd... No 1/8" plug?
I didn't realize that your motor was set to 9.8 comp. I was looking at the specs and with the 585 cam it bleeds off to 179 ccp. with the 570 (which is very similar to the 585) I'd bet it would perform better with the 40* ivc as compared to the 45* ivc. I wonder if anyone has tried it with that cam....?
Not knocking your motor or anything like that.. Just Curious, That's all....
