Exhaust question
Old Jan 26, 2018 | 07:35 AM
86glider's Avatar
86glider
Default Exhaust question
Wondering if later style bagger head pipes will work on 86 slip ons ? Can the flares be cut off to match the pipes.Would like to keep em.Thanks for any suggestions
Old Jan 26, 2018 | 10:12 AM
grbrown's Avatar
grbrown
Unlikely IMHO. The other way round will work, in other words cutting off the flare on your pipes will let you use later mufflers. The earlier mufflers fit inside the pipes, while later mufflers fit over the pipes. Pipes up to 2008 will retrofit, although some '07 and all '08 pipes have O2 sensors, so will require blanking inserts.
Old Jan 26, 2018 | 01:53 PM
Jakzen's Avatar
Jakzen
On my 96 RK, I've had both types of pipe on the stock header pipes. When I got it, the mufflers went on over the pipes, I aquired a set of Kerkers (sound really good, but found something I like better :-D) that went internal. Wouldn't fit, so I used a tail pipe expander from one of the auto parts stores and stretched it out a little bit. Should work the same on both ends.
Tom Watkins
Exhaust System Topics
Sep 27, 2016 08:11 AM
ssandstrom
EVO
Dec 11, 2014 11:50 PM
unfound
Feb 24, 2012 06:42 PM
County Po Po
Jan 30, 2012 11:24 AM
scooter34
May 2, 2009 11:51 PM
