Pingel vs Golan
Old Apr 19, 2018 | 07:54 AM
Racepres's Avatar
Racepres
I had issues with no reserve and running out of fuel with my pingel. If I put the valve on and turn it all the way till it stops, the port on the inside will crack open to the reserve port a smidgeon and will drain the fuel to the reserve level and run out. It's imperative to put the lever clearly in the on position and not past it.... I probably should send it back for a lifetime repair... Maybe next winter...
That don't seem right... my Pingel[s] have reserve [if equipped] in the Middle... On and off are to either side.... Pushed all the way to the Stop, I can't see being near the "reserve".. Is yours Much Newer or Older?? Betting Pingel would Replace that one for you..
Course... Possible Mine are the ones that are Older... ain't bought a New one in 20 Years!!!
Old Apr 19, 2018 | 03:47 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I currently have my tanks of, so I will check in the morning..
Ok so I went to the shop tonight and checked out my Pingel. I was a little wrong. The problem is when it's on the on position it is still cracked for reserve draining my reserved and unfortunately I ran out of gas twice.. the video shows it best...
Old Apr 19, 2018 | 09:03 PM
aces&8s's Avatar
aces&8s
[QUOTE=98hotrodfatboy;17289713]I currently have my tanks of, so I will check in the morning..
Thanks for the video, good to know but never had a problem with my pingle except when I forget to turn it on.
Old Apr 19, 2018 | 10:07 PM
Racepres's Avatar
Racepres
Hmmmm. I just slap the Booger to the Stop, and have yet to experience a problem...
Stop vs Detent???
I will stick with the Pingel.... But... they are in the Business and a Strong supporter for my Particular business!!!!
Old May 22, 2018 | 04:00 PM
steffridesabuell's Avatar
steffridesabuell
Default Golan wins
I also have both; the Pingel on my Buell and he Golan on my FXRP.
I recommend the Golan for two reasons.
1. Those detents are nice.
2. Pingel may have a lifetime warranty, but do you have the time to drain the tank, send your petcock back to Pingel, wait for it to get rebuilt, wait for it to get sent back to you, put it all back together...do you get where I'm going with this?
I have had both petcocks for about six years. In that time I have rebuilt the Pingel twice--I bought the very expensive rebuild kit so I could fix it myself--but I have never had a problem with the Golan.
JesseDyna
EVO
39
Aug 22, 2019 09:44 AM
MikeBel
Oct 6, 2018 08:02 PM
diiulio
Feb 14, 2012 09:34 AM
texasridr
EVO
May 16, 2009 06:55 PM
johndeere58
May 27, 2008 01:19 PM
