On the TDC issue. It is actually 5* degrees from center of the hole, and that's a lot.
There were always rumors about them being unbranded 2000i/p units,,who knows.
they ARE identical, and yes..you can reprogram using ( or used to be able to) Dyna's own software.
Dynatek Curvemaker software can be used to program 4 different types of ignitions, all manufactured by Dynatek and relabeled for the specific application. The software can be downloaded here: http://www.dynaonline.com/support/do...NA%202000%20HD
You also need a programming cable to use the software with a windows PC. Dynatek sells the cable or you can get a cheaper USB version, search for VRUSB2000i.
Been wanting to try a different ignition on my 94. I get some pinging with the stock ignition under a load. Have retarded it a little and even adjusted the Voes some with no luck of fully eliminating it. Kind of leery of Dynatek as I've had 3 units go bad on my Kaw drag bike. Finally switched that over to something else.
If Im not having any issues with my stock ignition module...should I replace it with an ultima? Would I see any benefit? And if so which one? Theres a few different ones. 1997 Softail
thanks
thanks
If it works and you're happy with it then don't fix it.
thanks
Try Daytona Twinntech.
It gives you lots of options without complications.
