Stripped torx
Old Jul 5, 2018 | 03:27 PM
Shem77's Avatar
Shem77
Default Stripped torx
I stripped the screw T40-45? in the fender stay. Im not sure how best to extract this. Any thoughts?
Thanks!
Old Jul 5, 2018 | 03:33 PM
Kingglide549's Avatar
Kingglide549
Cut a slot in it and hit it with the impact screwdriver,
Old Jul 5, 2018 | 03:59 PM
Dr.Hess's Avatar
Dr.Hess
Left handed drill bit. The slot thing works too. Use a cutoff wheel in a dremel tool.
Old Jul 5, 2018 | 05:59 PM
Shem77's Avatar
Shem77
thanks ill try and let you know
Old Jul 5, 2018 | 06:10 PM
im's Avatar
im
Unfamiliar with exact bolt but is it possible that bolt has a thread locker that requires heat prior to removal?
Old Jul 5, 2018 | 06:14 PM
barneyboy's Avatar
barneyboy
Try this before you break out the dremel. First confirm the correct driver, T40 or T45. Source some fine sand, (mason's sand, pool filter sand, or scrape some off of fine sandpaper). Dip the tip of the driver in water, and then the sand. Then use a impact driver. Many times, the sand will create enough "bite" to free the fastener. I've done this on recessed fasteners when cutting a slot was not an option. YMMV.
Old Jul 5, 2018 | 06:49 PM
blackxpress's Avatar
blackxpress
I always take a torx bit one size larger and pound it into the hole. It’ll cut its own grooves.
Old Jul 5, 2018 | 07:28 PM
johnjzjz's Avatar
johnjzjz
its a 5/16 drill bit to the center and take the top off
Old Jul 5, 2018 | 07:55 PM
barneyboy's Avatar
barneyboy
No doubt it works for the smaller sizes. Best be swinging a big hammer when cutting grooves on the larger sizes.
Old Jul 6, 2018 | 04:01 AM
grbrown's Avatar
grbrown
Thumbs up
That's how I helped friends service their Jap bikes back in the 1960s. All being well the drill vibration will jog the darned thing loose before the head comes off.
