Rear cylinder richer
Old Jul 9, 2018 | 10:43 PM
aces&8s's Avatar
aces&8s
Originally Posted by Kingglide549
My bike runs very well.
i am not going to give you a list of all I have done to it, but it is a long one.
This year I am trying 50 deg valve seats.
Raised ports.
With a carb and high CR numbers, its is a piece of mind.
You don't need purrfect numbers, just ballpark for your situation.
Purrrfect is for F.I,
Most everyone knows HD engines do not like lean numbers. They run hotter an hell.
I agree. My last Evo had 210 lbs cold, with 10-1 compression. Spent a lot of time tinkering to get it right and not ping on a hot Georgia day. The engine I have now is S$S 111 stock from factory and it runs so well Im not going to screw with it. S$S knows how to set up their engines and Im leaving good enough alone.
Old Jul 9, 2018 | 10:51 PM
Kingglide549's Avatar
Kingglide549
I only have 80 or so inches to work with here, so to be a big dawg i have to up the ante a bit.
My AFR is really important and it should be to everyone that has actually modded their bike.
( I am not meaning the stage crap that HD sells )
It is quite delightful to be cruising out through Midwest to or from Sturgis, 2 up, HVY, and look dwn and see 12.5 @90MPH
This bike will do that all day long in very hot weather.
If I depended on "reading" a plug I would be in big big trouble.
Old Jul 9, 2018 | 10:57 PM
aces&8s's Avatar
aces&8s
That's why I love the 111, 9.8 cr with no mods and runs like a dragster. love this engine, id say its near perfect without building too much heat.
Old Jul 10, 2018 | 04:54 AM
55 Pan's Avatar
55 Pan
you can chase a motor for days by trying to read a plug, with or without an AFR.
after riding since the early 70s, Ive heard, done, tried probably every trick in the book, and here is what I have learned in the long run.
If the bike is running well, if you aren't fouling( rich) plugs from being over jetted, if the plugs remain with an over all *** tanish colour *** mostly stop n go and backroads.
with stop n go, and back roads and interstate riding) and they still remain a nice colour stop chasing an issue that isn't there.
You can chase that perfect * strap burn. depth of carbon down on the insulator etc etc etc etc till you are a pure expert with all phases of your engines tune, and in the long run...unless you are chasing that 1/100th of a sec. it matters little.
ride and enjoy your bike, unless there is a problem...don't fix it. we will always tweak* an 1/8th or so of a turn on the idle lean/rich mixture depending on a few variables.but if you are transitioning from off idle through midrange and coming up on the cam, through to highways/interstate rding with a smooth and strong pull...ride the bike...
Old Jul 10, 2018 | 06:06 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Those plugs look pretty good to me.. Although an AFR meter with wide band will confirm..... Been using one for years now AND, most all pipes come with 12 or 18 mm bungs (new pipes)
Old Jul 10, 2018 | 09:10 AM
Kingglide549
The problem is- the carb can be running fat in one area and lean in the other.
in a stock 8.5 CR engine it probably will not ever matter.
But, once the CR is jacked up it starts to get really important in all areas
The AFR meter makes it very EZ to tune, or a holy piston might unexpectedly arrive.
Old Jul 10, 2018 | 09:14 AM
user 47363638's Avatar
user 47363638
Thanks for all the feed back, I think I got it dailed in as good as I’m gonna get it. 55 Pan my philosophy is similar to yours, I’m just trying to get it where I don’t have to worry about it running too lean.
Old Jul 10, 2018 | 12:20 PM
0maha's Avatar
0maha
As our own Dr. Hess says, "Too rich leaves performance on the table, too lean leaves pistons on the table."
One of my former engineering instructors used to say "Don't put yourself in a position where you measure it with a micrometer, mark it with a piece of chalk, cut it with an axe"
Rickierockit92
Shovelhead
Jun 5, 2018 08:27 PM
JustDave71
EVO
17
Jan 9, 2011 08:40 PM
Thermoman
Exhaust System Topics
Mar 18, 2009 09:52 AM
Z
Jun 6, 2006 01:06 PM
joker
Sep 27, 2005 01:25 PM
