The key here is to snug all 4 bolts so the Gap is equal between the top cover and bottom mounts. Then in a cross pattern snug each a little more till tight. I would think some where in the 20lb range with a 3/8's drive rachet just like your rocker bolts. A little blue loctite wouldn't hurt either..
This is from a Harley riser kit, using stock top clamp. Its what I followed for mine, but mine are BungKing steel risers.
Adjust handlebar to the desired position, verify that it is centered on the risers, then tighten the front socket head screws to 1620 Nˇm (1215 ft-lbs). There should be no gap at the front of the risers.6.
Tighten rear socket head screws (2) to 1620 Nˇm (1215 ft-lbs).
If your risers are in good shape you should be able to tighten them incrementally until the bars don't move anymore.
Try to get a similar torque on all the fasteners.
If something strips out or breaks, then it is because something wasn't in very good condition and you don't want that on your bike anyway.
No need for a torque wrench.
Tall handlebars (ape hangers) give the rider more mechanical advantage over the holding power of the risers so they will require more torque than lower style bars.
