The factory parts catalog for my '93 Ultra says that the rocker box cover socket head screws are: "P/N 882, Screw, 1/4-20 x 7/8, knurled socket head., Grade 8 Steel"
Are they really Grade 8 steel? Do they need to be? They only need to be torqued to 10-13 ft-lbs so it seems like overkill.
I'm asking because I'd like to buy chrome replacements which are readily available in 18-8 stainless (Bolt Depot, McMaster-Carr, etc.), but harder to find in chromed Grade 8 (although I did find them on the "Allen's Fasteners" website).
Harley does not use Grade 8 on anything in the rocker box. I've taken tons of them apart, and broken some based on too much torque even though it was was in spec.
Go buy some good replacement Grade 8 fasteners at Fastenal or something where you know you're getting Grade 8.
Oh, and to answer your question Grade 5 is plenty strong for rocker box work, although most of the allen head cap screws I can find locally are black oxide with no grade level (although they're hard as hell).
Just buy a new set from Colony, or Drag specialties. You'll get all chrome bolts and washers and the correct gaskets to go under the top washer. Last time I tried to piece together a set and Harley was out of the little gaskets. eBay is great for this as a source. And the chrome bolts look a lot better.
That's just the grade common caps head screws come in. Put whatever you want that fits in there and it will be fine.
Once upon a time... before cheap Chinese crap...all socket head cap screws were grade 8...they didn't come in any other grade...still are if you go to a bolt store...
The factory did not call for any grade 8 socket head screws in the early Evo manuals, but the spec for the small socket head screws that hold the rocker box cover changed from part number 852 to 882 for the `91 model year (grade 8).
The 5/16-18 hex head bolts have always been specified as grade 8 (Part numbers 3500-3501).
