cracked gas tank mounts
Old Jul 29, 2018 | 08:03 AM
glidein wide's Avatar
glidein wide
Default cracked gas tank mounts
Left side,both top and bottom mounts are cracked and traveling. Gonna need a small plate or something welded to the back side on each. Hope it can be done without ruining the paint !!
Old Jul 29, 2018 | 08:38 AM
Dr.Hess's Avatar
Dr.Hess
Might be better to braze it. The hardest part will be finding someone to do it.
Old Jul 29, 2018 | 08:41 AM
Kingglide549's Avatar
Kingglide549
Tig is much more direct and cooler to the sournding area.
Old Jul 29, 2018 | 01:20 PM
Sparkman.61's Avatar
Sparkman.61
3rd Gear
If you can, run the exhaust from a running car into the tank while you weld it to take car of any fumes. Rinsing an empty tank 3 or 4 times with water isn't enough and your tank might look more like a beach ball when you are done. I found that out the hard way.
Old Jul 30, 2018 | 04:35 AM
55 Pan's Avatar
55 Pan
Im not a welder, But I didn't sleep at a holiday inn either.
I have a guy that welds all my tank repairs for me ( mostly shovelhead tanks), and has been a welder with his own shop for the best part of 40 years
what he has me do, is put it in a sink, run hot soapy water in it initially till almost full, then shake it around then empty..after wards, back in the sink, and let water run in the tank for about 15 minutes, dump shake again with some water in it and repeat.
after that he has no issue with Brazing... Now if it has a liner in it?? he wont touch it, he feels that gas and gas vapors get trapped* between the liner and the tank..
Old Jul 30, 2018 | 05:27 AM
Kingglide549
This has turned into a welding lesson and most here would not know a wire feed from a hammer weld.
Old Jul 30, 2018 | 03:25 PM
glidein wide
thanks man I did line the tanks when I bought them
Old Jul 30, 2018 | 04:09 PM
megawatt's Avatar
megawatt
glidein wide,
Since you are talking about the mounting tabs and not the tank itself that have the cracks, I'm thinking that putting water into the tank and positioning the tank so the water is next to where the weld needs to be done will be sufficient.
Like Kingglide549 said, a TIG welder will concentrate the heat from welding enough that your tank liner and paint might survive the work with water in there to absorb the heat traveling outward from the weld.
You did not post pictures but the picture I imagine in my head looks to me like this is a possible repair with minimal damage.
Have you spoken to any welders yet about this repair?
Old Jul 30, 2018 | 04:31 PM
glidein wide
Hopefully I can do something like that,spoke to one person about it,but haven't shown him yet.
Old Jul 30, 2018 | 05:16 PM
Hey Man's Avatar
Hey Man
I'm not a welder but I have welded on a bunch of tanks. I wash them out with Tide Liquid laundry soap and hot water. I wash it , dump it, wash it again then put a garden hose in the filler and let it run for a few minutes to rinse. By then all the smell is gone.
