Evo oil level
Old Sep 4, 2018 | 02:47 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by 0maha
I like checking it hot, just so you can be sure any oil that might have sumped into the cases is pumped back into the tank first.
This right here. Always check it hot or risk overfilling.
Old Sep 4, 2018 | 04:44 PM
aces&8s's Avatar
aces&8s
Not to be confusing the Softtail info... THE DYNA , engine oil is checked on the kick stand, leaning.... DYNA Tranny are checked standing straight up and with the dipstick dipped, or NOT screwed in.
Dyna primary fluids are filled with bike straight up and fluid to bottom of big round diaphragm spring.
{ Just so people know all HD are not checked the same. }
Old Sep 5, 2018 | 03:27 PM
Uncle G.'s Avatar
Uncle G.
All that is so, but given the OP’s username, I naturally assumed we were talking about Evo Softails.
Old Sep 5, 2018 | 03:38 PM
Softail93's Avatar
Softail93
6th Gear
Now that I am sure of where the level needs to be I have a second question. Since I didn't inspect the shops work and rode for several hundred miles with too much oil, could this cause base gaskets to leak?
Old Sep 5, 2018 | 04:00 PM
0maha's Avatar
0maha
No.
The oil level on a dry sump system like these bikes have is not all that critical. The oil pump pulls oil out of the bottom of the tank and returns it to the top. As long as there is enough oil in the bottom of the tank to ensure that the pump isn't sucking air, you're fine.
As for the weeping at the base gaskets, that's normal for a stock Evo. The stock gaskets, now 25+ years old, are just paper and they deteriorate with time. When I bought my '90 Electra Glide a few years ago, I thought I got lucky and got a dry Evo motor. It only had 10k on it at the time. Now, with the mileage at 40k, it's weeping, but not as bad as my Sportster (30k miles or so on that one.)
f you're inclined, you can spend a Saturday and pull the top-end to re-gasket it, or just live with the weeping. Of course, if you decide to dig in, then the "may as well's" and "as long as I'm at it's" kick in, and you'll end up with new pistons, a new cam, ported heads and a new ignition module.
Old Sep 5, 2018 | 04:01 PM
Tommy C's Avatar
Tommy C
I wouldn't think so. Usually when the oil tank is overfilled the dipstick blows out & dumps oil on the side of the bike. If the bike has stock base gaskets they all end up leaking sooner or later.
Old Sep 5, 2018 | 05:25 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A bike with too much oil will either blow it out the breather or as mentioned pop the oil cap and dump it on the side of the bike.
Either way it hurts nothing but it does cause a mess.
Old Sep 5, 2018 | 06:18 PM
aces&8s's Avatar
aces&8s
I did not want other readers to think you check all HDs the same way, as I stated in my last sentence.
Derek Socalsinnershiner Matteson
Oil Archive (no new posts)
Apr 10, 2018 12:25 AM
mballard
Shovelhead
Sep 13, 2012 03:32 PM
300SRT8
EVO
Jun 6, 2012 10:02 AM
Kski
Mar 19, 2008 12:04 PM
wrinspect
Shovelhead
Jan 4, 2008 08:35 AM
