Replacing FXRT crossover tank line
Old Sep 5, 2018 | 05:01 PM
stroker23's Avatar
stroker23
Smile Replacing FXRT crossover tank line
I've replaced this line before I reached 70 on the odometer. Any easy suggestions or helpful hints replacing this line or must fairing be taken off. Thanks in advance. Getting old sucks,
dan
Old Sep 6, 2018 | 01:41 PM
brad75raiders's Avatar
brad75raiders
Well Not that this is correct or what you should do but I grabbed 2 "alligator clamps" also known as roach clips. Pinched the tubing on one side if the fairing then in the other . I then cut in the middle of the two clips so I could remove my tank. When I replaced the tank I just put a brass fueline fitting in secured with hose clamps then removed the alligator clamps easy peasy.
Old Sep 6, 2018 | 02:54 PM
Beemervet's Avatar
Beemervet
There is a quick disconnect fitting available for that line. Mas easy peasy.
Old Sep 6, 2018 | 05:29 PM
aces&8s's Avatar
aces&8s
Tried that metal QD and was too tight to work on my 97 dyna. I went back to a rubber fuel line called "Barricade". It is impervious to methanol or any alcohol gas. You can get it at NAPA.
Old Sep 7, 2018 | 03:53 AM
galtjunk's Avatar
galtjunk
The plastic quick disconnects suck.
I haven't tried the metal ones yet.
Old Sep 7, 2018 | 06:17 AM
grbrown's Avatar
grbrown
Thumbs up
Agreed, but they kind of work. For a confined space which I suspect stroker is dealing with a metal one is worth considering. For my plastic one I used extra tubing to create a loop, which made access a little easier.
Old Sep 7, 2018 | 11:34 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I haven't tried the plastic ones but the metal ones I put on my softails work great.
However you do need to have some room to install it.
A friend of mine just tried to put one on a 97 dyna wide glide and he didn't have enough room between the two sides of the tank to fit the quick disconnect.
IIRC he siad his crossover tube is only 4" long and the quick disconnect is 3" long leaving him with only 1/2" of hose on each side.
Old Sep 7, 2018 | 07:18 PM
Beemervet's Avatar
Beemervet
My brass QD is great.
AND... Yes a QD makes a huge difference that most don't want to understand because of the cost.... Tough luck for them...
Old Sep 8, 2018 | 05:53 PM
stroker23's Avatar
stroker23
Thanks for all the tips and suggestions. A QD is out of the equation cause the line is only 4'' long,
thanks
Old Sep 12, 2018 | 01:15 PM
GREENOHAWK69's Avatar
GREENOHAWK69
97 WG and I have a metal QD installed. I used new fuel line and made it longer so I'd have more to work with.
16VAFXDL
Feb 13, 2011 08:49 AM
Robtarra39
Jan 23, 2011 09:23 AM
Woodchuck
May 2, 2009 11:08 AM
keno
Sep 10, 2008 09:15 PM
gliderman
Mar 6, 2006 12:26 PM
