Replace Lifters on 1200 Evo
Old Sep 10, 2018 | 07:28 PM
ajay1976's Avatar
ajay1976
Cool Replace Lifters on 1200 Evo
Hello
My 88 EVO 1200 (23,000 miles) has lifter noise, seems getting worse. Question-do I need to replace pushrods along with lifters, rocker gaskets, or can I just get new pushrod seals? trying to keep cost down, but it already looks like about $350 in parts.
Thanks
Arnie
Old Sep 10, 2018 | 08:23 PM
Dr.Hess's Avatar
Dr.Hess
Is this a Sportster?
Old Sep 10, 2018 | 09:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by ajay1976
Hello
Thanks
Arnie
Unless your pushrods are bent you don't need to replace them.
It has to be.
There was no 1200 big twin in 88.
Old Sep 11, 2018 | 03:09 PM
ajay1976's Avatar
ajay1976
Yes it is. Original motor/mileage
Old Sep 11, 2018 | 03:31 PM
Dr.Hess's Avatar
Dr.Hess
Are you sure it's a lifter? Have you poked around with a mechanic's stethoscope to find it? I have not heard of a lifter problem with those motors, and at that mileage, if original, that motor is practically new.
Assuming it is just a lifter, then, no, you don't need push rods if you take the valve covers/rockers off. You will need rocker box gaskets and I would do the push rod tubes also, plus the lifter block gaskets.
Old Sep 11, 2018 | 06:49 PM
ajay1976's Avatar
ajay1976
I used a stethescope and found two front lifters noisy. I will do all four of course..
Old Sep 11, 2018 | 07:10 PM
misfitJason's Avatar
misfitJason
S&s lifters!
Old Sep 11, 2018 | 07:18 PM
Dr.Hess's Avatar
Dr.Hess
What kind of oil filter are you using? What weight oil?
Old Sep 11, 2018 | 08:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If those are original lifters, they should be replaced no matter what the mileage.
Those old design "A" type lifters had a lot of failures of the rollers.
Old Sep 12, 2018 | 09:09 AM
ajay1976's Avatar
ajay1976
I use std HD filter and 10-50 HD oil. Never a problem with that-and bike does not use any.
Thanks - I was wondering which brand to use. Don't want to buy based on price. Been skinned there before.
