Primary chain case question.
Old Oct 14, 2018 | 06:33 AM
Stiggy's Avatar
Stiggy
Now that we've settled the venting issue, the inner primary seal is probably suspect in the oil leaking down the inside of the inner primary.
Old Oct 14, 2018 | 06:48 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Hey Man
I knew there had to be some kind of a vent somewhere. So, the primary vents into the the trans and the trans vets back into the primary? That's funky. What happens if one of those vent ways gets compromised? neither gets vented?
1. No oil up in that area
2.&3. Most of the oil is located under those areas.
4&5. Never though about those. Thanks.
You wouldn't believe how small the vent is on a Baker transmission.
Sounds like it's time to pull the inner primary and replace a couple of seals.
Old Oct 14, 2018 | 09:00 AM
Uncle G.'s Avatar
Uncle G.
No the transmission vents to atmosphere through a "U" shaped tube that exits the left side of the transmission behind the shifter.
Old Oct 14, 2018 | 05:42 PM
splattttttt's Avatar
splattttttt
Thinking twinks utilize a similar vent routing system
Old Oct 16, 2018 | 07:08 AM
Hey Man's Avatar
Hey Man
I reckon so.
Yup, maybe next week. I was hoping I was done working on these things.
My Shovelhead trans vent was a tiny hole drilled through one of the top cover screws
I'll be needing to look at that.
iflybyu
May 16, 2015 06:38 PM
beary
EVO
Mar 11, 2015 02:46 PM
Kustrud
May 31, 2014 08:33 PM
wernett9
Jun 7, 2009 09:22 AM
ron1953
Shovelhead
Mar 20, 2008 06:13 PM
