Yeah, like Mike sez. If you have an aftermarket external module, then you definitly want to go with either the HD or the Standard one. For the cheap way out, put the Standard one on exactly as the OEM one is there now, then check the timing with a light. If your bike is running now with the old one, then might be a good idea to check the timing before you tear it apart, then put the new piece on and check the timing and set it to where the old one was.
Did yours work out good for you? Im in same boat now after getting my bike weeks ago. I discovered mine melted also dont look bad and I dont know how long I got. Its original factory one. Will it affect you when riding if it goes out going down the road or just only on starting the bike? Mine is not corroded from moisture either but cover screws one was real loose. Now I have stage 3 on the bike with a Andrews cam. So it should have a upgraded programmer or something installed already. Ill have to look under the seat to see. So dont think a dyno 2ki probably wont do me any good of I got one under the seat but if not then I may go that route. Factory Harley part is pricey.
I did end up going with a Dynatek unit. Not a difficult install. My problem wasnt the sensor, it was a leaking intake manifold at the rear cylinder head (like someone said above). I didnt sell the bike after all, and it starts instantly and has run with zero issues since. Id recommend it.
Harley factory is $225 and they got one locally. I got to see what module in bike got to be aftermarket since its stage 3. Not sure which dyno2ki it is. I seen $170 and I seen $273 prices. If I have after market module then I would not need the dyno2ki right? Or would it matter what programmer module I got? Ill check tonight see whats under the seat. But looks like cheapest if by much the standard manufactured one you mentioned. If oit one on exactly way it sitting now is there a garuntee it will be set the same on timing? Or can it still be off some?
JMO here but even if you have an aftermarket module you should go ahead and get the 2ki.
Your bike will start way easier.
Kinda what Im thinking honestly. I can get a ultra kit put in way cheaper than a factory one at dealership. But so many here like the dyna and Im betting its my best bet not sure if I like
something I read about ultra programming it part not really setup programmed for the bike or something like that. If I can do it and not be hard I prefer to do it. Tonight Ill check see what a under the seat what I got. Make sure all will work together or if it has to be disconnected. Im told it will if I got the ultra kit.
