STIFF clutch lever
Old Mar 10, 2019 | 10:53 AM
sB43's Avatar
sB43
Default STIFF clutch lever
I installed a new Barnett diaphragm spring, and new clutch line last fall before I stored her. Lever is STIFF as a wedding night D--k! Any suggestions?
Old Mar 10, 2019 | 11:50 AM
Racepres's Avatar
Racepres
What spring did you install??? Is it more stiff than when ya put it away?? Lubricated the Cable?
Old Mar 10, 2019 | 02:30 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That is the source of your stiffness.
Go back to an OEM diaphragm spring and you will be fine.
If you really like the Barnett you can buy a ball and ramp set up that has shallower ramps that help a bit.
Old Mar 10, 2019 | 04:07 PM
aces&8s's Avatar
aces&8s
Check for dry or bent cable first.
Old Mar 10, 2019 | 05:04 PM
Greezey Rider's Avatar
Greezey Rider
Do some hand exercises.
Old Mar 10, 2019 | 05:20 PM
texashillcountry
Dirt don't hurt
If he rides his bike he will get all the hand exercises he needs just operating the clutch.
Old Mar 11, 2019 | 08:50 PM
daven9113's Avatar
daven9113
If nothing is binding,etc....I've had great luck using this: http://clutchlite.de/en_product.html
Old Mar 12, 2019 | 05:15 AM
86glider's Avatar
86glider
My 86 had the same problem, asTHC said go back to the stock spring. Oh, and I like your first description,lol.
Old Mar 12, 2019 | 02:11 PM
tomfiii's Avatar
tomfiii
If no problem when put away,lube cable and re-adjust.Is your clutch measurement correct within .010
Old Mar 13, 2019 | 08:23 AM
galtjunk's Avatar
galtjunk
The last time I replaced my cable, the pull went from awful back to easy.
Jsvwrestle
Jun 18, 2018 07:54 AM
Jsvwrestle
Jun 11, 2018 02:05 AM
CGLTD
Feb 12, 2014 04:00 PM
Jarhead13
Jul 3, 2010 07:10 PM
MAX EVO
Nov 14, 2007 03:31 PM
