I ride an '88 Electra Glide (FLHTC) with a 1337 cc Evolution and a 42mm (I think) Mikuni carburetor.
The odometer reads greater than 90K.
It starts promptly, idles well, and runs smoothly.
The plugs are clean.
It's tuned... seemingly well.
It's a pleasure to ride.
While running well, at best it delivers about 29.5 MPG.
When I keep the tach at or above 3000, the MPG goes down... but the engine purrs.
With no complaints or concerns, I'm curious what kind of mileage other vintage Evo riders are getting.
Will changing the carburetor jets improve the mileage per gallon?
I can tell you my 86 FLT gets around 42-45 and that's w/ S&S carb,ev13 cam and programmable ignition. Definitely seems low. Does sound like a carb issue. Others here will chime in to answer your carb questions.
1987 Heritage. Totally stock. From new till about 75,000 miles got a good 50-55 MPG. Over 130,000 now with one valve job a couple of years ago. Averages 40-45 MPG now. Still runs great and very reliable.
37.5 on my 94 Road King - 4 gallons = 150 miles. Close to 60K miles, had the top end done and a cam a few years ago, If I babied it a little, I could probably get 40+mpg, but what fun would that be?
Mikuni's are known to get low fuel mileage out of the box because they are trying to cover a wide range of engine sizes but is a great carb. Best advice is to install a Joe Minton mileage kit in it, attaching the Holy Grail article of Mikuni tuning, Joe wrote it and his personal advice for the mileage kit is at the bottom.
38-42 mpg on my 93 FLHS EVO, street ported heads, tuned CV carb, EV27 cam, Thunderheader, and Dyna 2000 ignition. I can sometimes best that on long rides, steady speeds, using the electronic cruise control. I mostly ride in the 70-75 mph range on the interstate, with brief spurts above that to get around trucks, RV's, and dumb-dumbs in cages.
On long rides, I generally start looking for a gas station around 140 miles.
I can vouch for the Mikuni mileage kit mentioned above. Ive run it in my 94 Heritage Softail for ten years. I easily get mileage in the mid 40s. Before the kit I got around 38-40 MPG. I did find for my bike I needed a #20 pilot jet instead of the #17.5 recommended. That eliminated a problem with closed throttle sputtering in cold weather.
Beg to differ, been running Mikuni's on various Harley's for 30 years and PROPERLY tuned they are Great carbs and can certainly improve rideability, power and milage. The key is to tune it correctly using the Manual provided by Mikuni. Don't have one? Go to their website. BTW: Built 88 FLHS, big cam, high compression and lots of other goodies, 90/90 and over 40 MPG.
