Leineweber E5S questions
Since I'm not building a racer, and engine being just 80" + 0.010, I will stick with stock valve sizes and stock sized CV. Based on my measurements and calculations this engine won't need bigger valves, yet heads needed quite a bit of work. For bottom end, no major changes; just honing the barrels, new rings and adjusting squish down to 0,85mm (that's 0.034" for those who does not speak metric
Harley quality back then was something that made me laugh; valve seats were not matching with ports, intake manifold was not matching with intake ports and so on. Well, I just saw that as an upside for my power plans...So that was the first thing that had to be done. After that, a little bit porting by removing all the casting imperfections and a bit of shaping for the ports, but mainly just blending different transition areas.
The most extensive, and exhaustive work for me was to reshape combustion chambers. I had three key initiatives with that; to make those flowing better, burning gases more efficiently and rise the CR without need to mill heads too much. As you will see from pictures, those heads are pretty unique, and therefore I'm looking for certain type of the cam...Surely I will first run that with my existing EV46, but those heads are, in my opinion, begging for a high lift short(ish) duration cam..or what do you think guys ?
Heads on that pic are not yet completely finished, but I think you'll get the idea.
Stock was 83cc.
And yes, I do have valve reliefs.
