Need advice on starter problem
Old May 15, 2019 | 06:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by RANGER73
Sounds like the solenoid's not activating the bendicks gear
If the starter motor is turning, then the pinion gear is engaged in the ring gear.
OP:
If the starter motor is turning but the engine is not, the starter clutch is bad.
If you get nothing when you press the start button, you need to start by cleaning all the electrical connections and grounds.
Start by cleaning the connections at the starter relay and solenoid. Replace the start relay, they are cheap.
Old May 15, 2019 | 12:43 PM
RANGER73's Avatar
RANGER73
If the pinion gear doesn't pop out to engage the solenoid is bad.
Old May 15, 2019 | 08:15 PM
RANGER73's Avatar
RANGER73
Originally Posted by Monsterhawg
Okay im about to give up on this site, you can do anything but start a new subject. ill try here for help. First I have to beg you al dont lead me to a fuel problem or a spark problem. My bike is a lemon, new engine, new carb new starter, solinoid, new just about everything. So i go to start it today , turns over like crazy, LOTS of juice, also im telling you now lots of fuel and lots of spark, its a 1987 electra glide, look theres blue great spark, cant miss it, theres fuel going to her , in fact you can actually spray all the starter fluid u want in the bike or pour all the gas u like in the cylinders, the fact is its not a fuel or compression or spark problem. cant be a weak coil cause its only a few months old as well. so, has to be electrical you say , ive gone threw the wiring from key to battery, everything is good. relay is fine, YES bought one anyways. good battery, good relay, 1987 so no fuses just one big old 30 amp circuit breaker, .My first dumb question of the day is will i still have spark and all lights and stuff if i screwed that circuit breaker???? Can that circuit breaker stop her from firing and only stop her from firing but everything else is okay. I cant stress to you all enough that the fuel, spark and compression isnt an issue so the first one asks ..Is she flooded??? i wanna pull my hair out of my head, for the last week yes the key was giving me problems, ran a toggle switch instead for the last two weeks, for main power before i hit the run button. cranks liek a brand new bike, no starter or solenoid or battery issues. Can my new coil be weak? could that be the only answer left????? old bike, simply built. all grounds seem good, everything reads 12,6 where it sghould, any suggestions or ideas guys... as many as possible please. Cant be the kill switch if shes turning over fast right...
Who the hell are you? Start your own thread.
Old May 16, 2019 | 09:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Well, I guess that one got kicked to the curb...
Old May 16, 2019 | 11:03 AM
Jake707's Avatar
Jake707
Do you have the direct button on the side of the starter? If so try that and see if it works better. The fact you said nothing happens sometimes when you push the button on the bars leads me to think it would be connection related. Having the solenoid button on the side of the starter motor eliminates that and would be a good test.
marc177s
Shovelhead
13
Jun 25, 2018 06:47 AM
Rescuediver1982
EVO
Jul 28, 2015 08:39 PM
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
wdb01l
EVO
May 31, 2013 09:59 PM
jason8251
Electrical/Lighting/Alarm
Jul 27, 2011 03:23 PM
