Dry Primary vs Wet
Old Dec 17, 2021 | 06:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Surprised no in this thread mentioned only 6-8 oz of tranny fluid is all that's needed when converting an older shovel primary... That's how I ran my 77 without issue...
Old Dec 18, 2021 | 12:01 AM
OLD 96's Avatar
OLD 96
With the aluminum primary there is no way to adjust the tension on the belt. Is that correct? On my Pan I can move the tranny to adjust the tension on the belt if needed. On the sealed aluminum primary it is what it is. Is that right? Or. Is a roller adjuster used? Am I missing something?
Old Dec 18, 2021 | 04:22 AM
98hotrodfatboy
Pretty sure BDL makes an idler to be able to adjust belt tension.. I have one some where...
Old Dec 18, 2021 | 09:27 AM
LowriderHarold's Avatar
LowriderHarold
Default It is adjustable
pretty sure bdl makes an idler to be able to adjust belt tension.. I have one some where...
double post
Old Dec 18, 2021 | 09:35 AM
LowriderHarold
I have the BDL belt drive system on my 66 FL.
I had to think , a minute & look up the instructions, but the idler & plate bolt up to existing hardware & idler is adjustable.
( For 11mm drives with idler, install plate and idler on existing serrated plate with idler under belt, proper tension of belt is 1/2" total up and down on top of belt and 1/4" on each side of idler)
(Copied from BDL's website.)
But the 55-64 kit does NOT have the Idler., so looks like no adjustment on those year models.
Ride Safe,
Harold
Old Dec 18, 2021 | 09:23 PM
OLD 96's Avatar
OLD 96
Ride Safe,
Harold
Not true. That is the point I was trying to make. On those years you can move the transmission forward or back to adjust the tension on the primary belt. Which is far better than having a belt tensioner. Which does nothing but build heat and wear on the belt. That is the reason why HD tried a primary belt for a year or two. Then **** canned that idea. On 1964 and earlier year models the belt drive is very advantageous. 1965 to 1984. Modify the primary to seal it off. Run a closed primary with chain. Nothing is more bullet proof than a chain in a enclosed primary.
Old Dec 19, 2021 | 08:09 AM
LowriderHarold
Default My bad
But the 55-64 kit does NOT have the Idler., so looks like adjustment is done with moving transmission on those year models is what I should have said.
You are right about adjusting the tension with the transmission.
I had a 51 FL for a while, but not long enough to adjust the primary chain.
My loss.
Ride Safe,
Harold
Tizza1013
Shovelhead
17
Jun 7, 2020 01:44 PM
lazosb
Engine Mechanical Topics
Nov 14, 2011 06:51 AM
1bad79fx
Shovelhead
13
Dec 4, 2010 10:09 PM
shortride
Apr 29, 2010 01:03 PM
rxdug
Shovelhead
Jan 29, 2010 09:25 PM
