Third time in 2 years transmission leak
Old Jun 18, 2019 | 08:02 PM
bagga's Avatar
bagga
Originally Posted by 800screws
No the pulley is for the 89 setup. Nothing has been replaced with the later evo setup.
I would be looking at the splines on the main gear. if the splines have a step you can feel with your fingernail on the sides of the splines...it's time to replace it.
Old Jun 19, 2019 | 06:32 AM
800screws's Avatar
800screws
Ok I’ll have to look into the shaft. Tearing it down this weekend
Old Jun 19, 2019 | 09:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You definitely should upgrade to the latest configuration front pulley, spacer, lock etc.
Also consider replacing the belt, it is 30 years old.
Pulley 40250-94c
Spacer 33344-94
Quad Seal 11165
Oil Seal 12035B (5th gear to mainshaft seal)
Oil Seal 12067B (big oil seal)
Nut 35211-91B
Lockplate 40251-92A
Screw (2) 3594
Old Jun 19, 2019 | 11:50 AM
Hey Man's Avatar
Hey Man
When you replaced the mainshaft seal did you use a dial indicator to check the mainshaft to see if it's true? If it's bent you'll never seal the leak.
cncmike
Jun 30, 2019 11:20 PM
Blowby
Jul 21, 2017 04:15 PM
LunaticFringe
Mar 25, 2017 02:56 PM
Sabaka454
Apr 19, 2009 11:53 AM
timbo
Aug 28, 2007 09:53 PM
