Evo brake question
Old Jun 24, 2019 | 06:29 PM
Jag Jim's Avatar
Jag Jim
Originally Posted by 0maha
That's more in line with what I was thinking. Was surprised to see these other comments of much shorter replacement intervals.
I suppose it comes down to what kind of miles. I do a fair amount of extended highway riding where I might not touch the rear for hundreds of miles at a stretch.
I could of went a while longer for sure, but thought as long as I have em off, and as big of a pain to get around that rivet, I''ll just replace them. Cheap insurance
Carl, I'm gonna take your advice and grind that rivet a bit. Thanks
Old Jun 24, 2019 | 06:44 PM
jonnycando's Avatar
jonnycando
Originally Posted by Beemervet
(sigh) 70% of braking efficiency is done by the front brake. Rear pads should last like Bass Player stated.
In traditional braking yes...but if you trail brake a lot as people who live in the mountains must the rear will not likely outlast the front.
Old Jun 24, 2019 | 08:10 PM
t150vej's Avatar
t150vej
124,000 on my FLT. Changed rear @ 32k because the pads separated from the plates. Replaced them again at about 85k and turned the rotor (to thinner than specs) and today pulled and measured the original front pads. Looks like they'll run another 50-75k. 7500 miles on the rear tire so I'll be checking them in about 3k - 4k miles.
Old Jun 24, 2019 | 08:58 PM
Dr.Hess's Avatar
Dr.Hess
Checked my log. Rear pads at 52708 + about 3, call it 56K. I think I'm still running those pads. I rebuilt the MC and caliper at 74K + about 4, call it 78K. Pads were still good so I left them alone and put them back on. Mileage differences are due to busted speedo senders and cables.
Old Jun 28, 2019 | 01:44 PM
Hey Man's Avatar
Hey Man
Originally Posted by carlgrover
I had so much trouble getting the rear caliper off that when I finally did, I ground that stupid rivet down on a taper so it wouldn't hang up again.
OK, what rivet?
Old Jun 28, 2019 | 03:28 PM
Jag Jim's Avatar
Jag Jim
Originally Posted by Hey Man
OK, what rivet?
On the Road King pads there’s a rivet In the center of the pads
When you go to pull the caliper, it gets hung up on the rivet
Took a bit to work the caliper
Not sure if the softail has the same type of pad
the way it looked in the video I saw, the softail pads came right off
Old Jun 28, 2019 | 04:50 PM
Mountainkowboy's Avatar
Mountainkowboy
For me it works out to about every other year for replacement pads on the bike...I also like mountain roads so I do a lot of trail braking.
Old Jun 28, 2019 | 06:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Here`s a pic of a Wilwood GP1310 on my `89 Softail.
The bleeder valve is in an impossible spot, I just bleed it while it is unmounted, with a piece of steel in it`s jaws...
Pads, clips, pins, retainers, seals easy to get from Wilwood, or Jegs.
Donald Mazz Derby
Jul 23, 2018 08:41 AM
flhxs103
2014-2024 Touring Models
Jul 9, 2018 02:23 PM
Hopper
EVO
83
Apr 4, 2018 07:15 AM
MercRider
EVO
Oct 1, 2007 11:26 PM
smithk
Jul 3, 2007 08:38 AM
