Ignition fuse blowing
Old Jul 10, 2019 | 01:17 PM
EVOrider's Avatar
EVOrider
Default Ignition fuse blowing
My 1998 FLHTCUI has developed a problem. It was running just fine down the interstate. Pulled up to gas pump and still idling....the bike just died. Could not hear the fuel pump whine. Mileage.....100,000 miles
I immediately checked the run/off switch.
Checked the two connections under fuel tank canopy that run to the fuel pump...they were fine. They are known to lose connection.
I swapped the relays around....no luck
The ignition 15 amp fuse was blown. Put in another and it blew as well.
Loosened up and removed the switch housing....all seemed good. I was thinking a pinched wire in there.
Removed the outer fairing....I didn’t see anything out of place.
After bike cooled off....it fired right up....still towed it home because I didn’t trust it.
I turned handlebars left and right while bike was running....no problem.
Bike has cooled off for two hours.....it blows the fuse as soon as I turn the ignition to on.
Now it just blows reguardless.....hot or cold.
The cam position sensor is original.....
The coil is original.....
Fuel pump is original.....fuse never blew
I have the shop book, breakout box, and a scanalyzer.
Any help to guide me would be helpful. I am at a loss on this one. I don’t want to start replacing parts until I know it failed and what caused it to fail. Of course....any recommendations to replace a part due due to age and mileage?
Thanks again
Old Jul 10, 2019 | 03:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
This should be fairly straight forward, since the fuse blows as soon as the switch is turned on...
The ignition circuit passes through 4 harnesses.
Main Harness
Interconnect Harness
Right Hand Switch (Kill Switch)
Ignition Harness
Disconnect the harnesses, one at a time, starting furthest harness away from the fuse.
Disconnect the ignition harness first, by unplugging connector 8A/B. Put in fuse, turn on ignition, see if fuse blows.
Follow with the connector for the Right Hand Switches, connector 22 A/B.
Old Jul 10, 2019 | 05:12 PM
EVOrider's Avatar
EVOrider
Cannot get it blow the fuse again......
Disconnected and reconnected a few times.....
Bike is running great and normal operating temperature.
I’m lost.....hard to fix a problem since it just fixed itself so it seems.
I like EFI.....but this is nuts. I’m really leaning towards the carburetor conversion.
Old Jul 10, 2019 | 05:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
It has nothing to do with carburetors or fuel injectors, both type bikes use electricity and wires.
You have a wire somewhere in the ignition circuit that has chafed itself bare and touches ground, it did not fix itself.
You need to get inside the fairing and look for where a harness moves when the bars swing back and forth, look for a section of wire that rubs.
Old Jul 10, 2019 | 05:41 PM
EVOrider's Avatar
EVOrider
I wish it did fix itself......
Finding that bad wire.....gonna take sometime.
Any ideas which wires could be causing this problem?
Thanks
Old Jul 10, 2019 | 06:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Come on man, read the post right before yours...
It`s going to take some effort, but once you move those bundles around a bad spot may jump out at you, go for it.
The wire color will be gray before it goes into the kill switch, it will be white/black after the switch all the way to the ignition harness.
Old Jul 11, 2019 | 08:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Try this: turn off the kill switch, then see if it blows the fuse when you turn the ignition switch on.
Old Jul 11, 2019 | 10:07 AM
Beemervet's Avatar
Beemervet
Step one: Buy a box of those fuses.
Old Jul 11, 2019 | 04:57 PM
EVOrider's Avatar
EVOrider
Tried that today....it’s not blowing. Even did that with handlebars to left and to right.
Old Jul 12, 2019 | 11:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Does it blow when you turn the kill switch on?
