Evo Questions
Old Jul 20, 2019 | 09:23 AM
AbnRanger4's Avatar
AbnRanger4
Default Evo Questions
Ok, so I got the 1997 FLHTCUI. I serviced it this time with Harley conventional 20w50 and Formula Plus in primary and tranny.
I have been told that I should try the following:
Engine - any good conventional 20w50 motorcycle oil
Primary - 10w40 conventional motorcycle oil
Tranny - 75w90 Synthetic year oil
All thoughts are appreciated. The only one that concerns me is the synthetic gear oil in the tranny. Some say yes and some say no way.
Old Jul 20, 2019 | 09:46 AM
Racepres's Avatar
Racepres
I personally avoid Hypoid/synthetic... and use about any Cheap *** 10w30 in the primary... Synthetic Blends [motorcycle specific] seem fine for the 20/50
or straight weights in older stuff... [I consider the late '90's as "New"]
Old Jul 20, 2019 | 10:10 AM
Dr.Hess's Avatar
Dr.Hess
I use synthetic ATF in the primary. I currently have Mobil SHC630 in my tranny, but will probably go to whatever Redline recommends for it when I run out of SHC630.
Old Jul 20, 2019 | 11:39 AM
GOGOBECK's Avatar
GOGOBECK
I swapped to synthetics after 10k miles on my ‘97 FLHR, way back in ‘99. I’ve been over 90k since without any issues.
Mobil 1 15-50
Redline MTL in the primary
Redline Heavy Shockproof in the transmission
I used HD 20-50 for an oil change once on road trip... it stayed cleaner looking a lot longer than the Mobil 1. Made me wonder where the contaminates went!
Old Jul 20, 2019 | 05:03 PM
user 47363638's Avatar
user 47363638
Lubrication is overrated, just change it as per manual, your engine doesn’t know what kind of oil it’s using.
Old Jul 20, 2019 | 05:07 PM
Stiggy's Avatar
Stiggy
Agree with above except I go with Walmart 20W-50 automotive in the primary at $2.59 / qt (Cause it's accessible and cheap (165,000 miles.))
Old Jul 20, 2019 | 06:42 PM
OLD 96's Avatar
OLD 96
I have heard that some Evo riders in hot climates use 60 weight dino oil. Because it lessens engine noise. I switched from Amsoil 20-50 to Amsoil 60 weight. I may try 60 weight dino oil next oil change.
Old Jul 20, 2019 | 06:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
20w50 is all any Evo needs.
No reason to dump SAE 60 oil into an Evo...
But some people would use SAE 70 if they could find it.
Old Jul 20, 2019 | 08:10 PM
Mountainkowboy's Avatar
Mountainkowboy
20-50 Dino oil in the engine, whatever is the cheapest in the primary, and Redline shockproof in the trans.
Old Jul 20, 2019 | 08:38 PM
EVOrider's Avatar
EVOrider
I’ve started using Mystic semi-synthetic 15w50 by the gallon at a Atwood’s store 10-$12. If not that....cheapest 20w50 I can find. A few winters.....I’ve run diesel 15w40, but never in the summer. Several years ago.....I rode out in Arizona & New Mexico.....ran 25w60 in really hot weather.
Primary.....I like diesel 15w40. I liked ATF fluid, but it always found the weakest part of the gasket seeped out. Whatever you use...avoid the conservation energy....ones with the star on them. Or your clutch might start slipping.
Transmission....just use gear oil. 80w90
