Evo Questions
What matters is that you are happy with what you like.
Use the lube you like
Like the lube you choose PEACE!
we've been having a very hot summer up here in the mid Atlantic/northeast so i change the motor oil more frequently.
I have been told that I should try the following:
Engine - any good conventional 20w50 motorcycle oil
Primary - 10w40 conventional motorcycle oil
Tranny - 75w90 Synthetic year oil
All thoughts are appreciated. The only one that concerns me is the synthetic gear oil in the tranny. Some say yes and some say no way.
But now, like mentioned earlier, our choices are endless. And do not end at what our opinions may differ. Whether its organic or synthetic.
And probably one of the most debated differences involving lubes.
Ao in my most friendly manner. I will like to state my own two cents involving heat dissipation.
We all know that heat robs your motor of power. Agreed?
And why do you suppose that is?
My opinion is that heat makes things if all nature expand. And in our case, that is what is goin to screw your motor!
So we keep our lube fresh. Because clean fresh lube will dissipate heat best. My two cents.
So thanks for baring with me, and sorry for the extra wind it took me to get this fine point out.
There is a difference. And for what ever its worth to you, the facts, remain.
So, take this only as a grain of salt. It is intended to point out why oranges can never become apples. Even if the box says its better than LOL
What is synthetic motor oil? Synthetic lubricants are chemically engineered to form pure lubricants. They contain no contaminants or molecules that dont serve a designed purpose. Their versatility and pure, uniform molecular structures impart properties that provide better friction-reduction, optimum fuel efficiency, maximum film strength and extreme-temperature performance conventional lubricants just cant touch.
Conventional lubricants, on the other hand, are refined from crude oil. Contaminating elements such as sulfur, nitrogen, oxygen and metal components such as nickel or vanadium are inherent to crude oil and cannot be completely removed through the refining process. The oil refining process separates the various types of molecules in the oil by weight, leaving molecules similar in weight but dissimilar in structure, reducing performance.
