Mobil 1 Trifecta: Whatcha think?
Engine: Mobil 1 V-Twin, 20w50
Trans: Mobil 1 Syn. Gear Oil, 75w140
Primary: Mobil 1, 20w50
For the primary, I was unable to find any indication if this 20w50 is the "V-Twin" labeled oil or just the "regular" stuff. Guidence here would be appreciated.
When I picked up my 2005 Softail, it had the Syn3 in it. Since it was "pre-owned", I changed all the fliuds and went back to the regular H-D dino oil. And been doing it that way every since.
My goal for changing to all synthetic is to hopefully quiet the engine/primary down a bit and to drop the operating temps a shade. I was going to order the "kit" from Redline, but need to get this done before the weekend. Thus, I'm kind of stuck to local stores.
- Am I on the right track?
- Does the primary lube need to be the "V-Twin" labeled oil?
- Should I forget the Mobil 1 change and just stick with H-D oils?
- What do you think?
Thanks...
I use B&M Trick Shift in my primary and like it better than any oil I've ever put in. But the primary is a very simple machine and almost any oil is going to do the job. You can go from the cheapest bottle of oil to the most expensive syn and you probably won't notice too much difference. If you plan on sticking with mobil syn then any of the car oils will be ok in the primary.
Living it the sticks has it's bennies... But not in this case. LOL!!
1: Stick with dino in engine (HD 360 or any other name brand 20w/50) 3 quarts oil and one quart Lucas oil stabilizer in the hot summer months. For Winter: - use 4 quarts dino or only 1/2 quart Lucas.
2. Primary: Use Type F ATF (works great) or just any dino 10w/40 oil or Rotella T 15/40.
3. Tranny: Use 75/140 dino gear oil (any brand)
