Ignition modules
Old Oct 22, 2019 | 01:48 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Dr.Hess
Nothing wrong with waste spark. My Esprit had it, my Camry had it, RAV4, Corolla, etc. HD just beat them all to it by a couple decades.
Now, RSB, you said
"They are all good that you mentioned,buy what you can afford but don't believe the guys who say there is no difference tween dual n single fire. I just put in an ultima ignition n an aftermarket single fire coil and the vibration on my bike was cut by atleast 40%."
From an experimental standpoint, you changed 2 things, the module and the coil, maybe 3 if the plug wires are now also new, and you said the bike vibrates less. What caused it? You can't pick one without further research. Put a new waste spark coil on in place of your single fire and see if there is any difference.
I have to agree.. I've run stock, Screaming Eagle (with selectable curves, single or dual fire) and Dyna 2ki in some pretty nasty builds and could never feel a difference
I wonder if it's possible the other guy had an issue with one of the components like the wires... A bad wire or even an incorrect wire will cause ignition problems when used with said ignition... Should only be using carbon core... Definitely not the steel suppression cables...
Old Oct 22, 2019 | 01:55 PM
Rsbenden's Avatar
Rsbenden
LMAO!!knew I'd get called out when I posted it. It's definitely a combo of coil& ignition. I may just slap the dual fire in n see what's up when I get home,pretty sure the cam n quick rods didn't smooth it out there alot at play,I also put in new lifters though the OEM only had 26k on em.
Old Oct 25, 2019 | 04:47 PM
Dehammer's Avatar
Dehammer
The Crane dies in heat. Rarely do I get that pissed but entire Crane experience made me livid.
I currently use Daytona, the one that mounts to the panel. Seems like a cooler solution than the cone mounted versions. I'm not a pro mechanic so this ain't a recomondation worth noting, it's just what I have.
Old Oct 25, 2019 | 07:02 PM
98hotrodfatboy
It's not about getting called out but when you make several changes it's hard to determine which one really smooth it out. You could have had a couple things going on there. Nobody's calling you out, we're just stating facts that's all..
Old Oct 25, 2019 | 07:22 PM
98hotrodfatboy
Honestly, that's why I like the Standard Motor Products Hall effect pickup in the cone with a remote ignition module...
Old Oct 26, 2019 | 04:35 AM
Rsbenden's Avatar
Rsbenden
Well I'll state a few facts,
I went ahead and switched the coil n to my surprise there wasn't much noticeable difference. I had a problem w the single fire coil. I believe the updated ignition did more to smooth it out than dual or single fire coil.....there's a difference but its only noticable at low rpm. In the end I'm actually running dual fire. I enjoy working on bikes so it's a labor of love for me away from life n wife where I spend my free time. I'm gettin to the point that any upgrades from this point are out of my pay grade n dislike having others do the work on my bike. I talked w Scott from Hillsidecycle.com n seems like a great guy. They are within driving distance for me,though still in the research stage I'll probably end up there.
Old Oct 26, 2019 | 05:19 AM
98hotrodfatboy
I know Scott well, I used to live up by him. Had several builds by him..Although his heads are some of the best out there some of his other work it's not up to par.. I've had major builds with major failures. I would recommend his heads but that's as far as I'll go anymore..
Old Oct 26, 2019 | 06:07 AM
Rsbenden's Avatar
Rsbenden
Thnx that's what I had in mind,if I knew of anybody reputable closer I'd consider them,I'm in the Erie,Pa area but really want to get a class A job done,there are many that proclaim to be top notch but I hate putting my stuff in other people's hands.
Old Oct 26, 2019 | 07:55 AM
Racepres's Avatar
Racepres
GMS in Uniontown, PA
Gregg really, honestly knows his ****!!!!
Old Oct 27, 2019 | 01:30 PM
Rsbenden's Avatar
Rsbenden
Nice this is 3 hrs from my house thnx!!
