Spark Plug Thread Repair
Yeah, weld up and re-drill/tap would be the ultimate..
The "pro" heli-coil kit is expensive as is the time-sert which I kinda like the looks of, but I'm stingy
I have used a lot of heli-coils over the years for other things with total success.There's lots of choices out there, many specific for ford engines. I'm a little gun shy of the ones that include a staking tool, though those inserts may work well as anything. I do like the idea of a 2 step reamer/threader. Again, I've never done one so have nothing but y'all's experiences to go by.
So, those that have used heli-coil kits, were those the coil type inserts like normal, (and look like you have to "stack" them to length?) or did you use the "sav-a-thread" that is marketed under heli-coil with one piece barrel inserts? And YD, the el cheapo set you used, was it similar to the time-sert style but with a different installer?
1997bagger's post got me thinking that if/when you have your spark plug hole welded and re-drilled you could have it filled enough to re-drill it for the smaller Screamin' Eagle plug which I imagine is available in a heat range you need.
If you cannot afford the weld repair right now I'm pretty sure you can fix the threads with an insert.
I have heard that Helicoils don't work well in spark plug holes but I haven't had to repair one yet.
If you intend to do this with the head on the engine I suppose you could put air pressure to that cylinder from the exhaust port fairly easily to blow the thread cutting chips out at the spark plug hole. I figure you would get at least most of them out.
I hope you post the results of whatever you decide to do.
Met a guy at Sturgis, maybe '87 or so. He had a shovel and was running the old style giant spark plugs, like tractors use. He had the regular plug blow out the head on him. Just drilled and tapped it for the large plugs and kept riding. He had a lot of miles on it too. Especially by shovelhead standards.
The set I picked up about 20 years is made by "Perma-Plug, from a farm and fleet store on sale for about 15 bucks.
https://www.walmart.com/ip/Perma-Plu...-Kit/199947031
It is the stake in place style, so might be a little risky with the evo head. Never had a problem with it backing out of the triumph head, but always wondered if it would I used red loctite when installing (along with staking it in per the directions) but with the heat, the loctite probably didn't help any in regards to holding it in place.
Do you have any planned down time with the bike? If you need the bike up and running then helicoil until you have some down time to get it welded up. There is a helicoil kit on amazon for 25 bucks. YD
