Electrical Headscratcher
Old Dec 19, 2019 | 03:15 PM
  #41
Mountainkowboy's Avatar
Mountainkowboy
Originally Posted by Racepres
My 1968 BSA still has stock Wiring!!!! Yes it is Lucas...and yes...It still works!!!!
Isn't that an oxymoron? Lucas...the people that invented darkness.....LOL. I loved my Norton but it always had electrical gremlins.
Old Dec 19, 2019 | 07:57 PM
  #42
almostakeeper's Avatar
almostakeeper
Soldering is way easier then the crimping system I used, mainly due to the large crimping tool I used to get into tight spaces.
But, I did do a good job and tried to pull apart each connection as I went. Not too hard, just a decent straight on pull
If I had to do it all over again, I would have ordered a large box of those new type of heat shrink tubes with the circle of solder in the center.
Old Dec 19, 2019 | 08:22 PM
  #43
TSheff's Avatar
TSheff
I use them at work for 22-14 gauge splices pricey, but they work great. I also have several crimpers ans pin & socket terminals for factory connectors. Nothing beats a neat color coded job.
Old Dec 21, 2019 | 11:08 AM
  #44
almostakeeper
Some borderline Genius installed the front brake sensor upside down pinching/grounding the red/yellow wire and a possible pinch on the orange/white. I didn't want to cut solder/heat shrink so I took a 1/4 " heat shrink, cut it, wrapped it tight around the wire, took some copper strands, tied em around to hold the heat shrink and hit it with the heat gun.
The wrapping looked good and its boxed up with other wires so I'm OK with em.
Buttoned everything back up, testing the lights as I went. Perfect, except
Back tire is off so I made sure the tranny was still in neutral, hit the start button, nothing.
On the black/red wire going to the starter relay, I stuck my 12V tester in the socket, with the kill switch on I hit the button, the light came on, turned the kill switch off hit the start button, no light. So I plugged the socket back in and hit the start button and it worked.
My question is, WTF. Is this in the same category as you stare into the refrig for a beer, nothing, close the door, open it and find a beer right up front.
Old Dec 21, 2019 | 12:15 PM
  #45
TSheff's Avatar
TSheff
I do this all the time at work also. Seems to easy, but cleaning contacts and reseating terminals and socket is a must. I do it before any other trouble shooting. You just found a bad connection and reseating the socket established continuity. The physical side of electrical circuits is so simple, it's when the wire plug into electronic and computerized devices that the VooDoo begins.
Old Dec 21, 2019 | 04:42 PM
  #46
almostakeeper
Was out messing around with the bike. For ***** and giggles I pulled the plugs and grounded them. Poured roughly a teaspoon of oil in each jug, waited a few minutes then hit the start button 3 times, about 3 seconds each. On a 4th attempt, nothing. I unplugged the relay, plugged it back in and it worked again.
My question, can relays work part time.
Old Dec 21, 2019 | 04:46 PM
  #47
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If your bike is developing the Dreaded Click the relays can work part time.
To fix the dreaded click all you have to do is run a 20amp fused wire between the positive battery post and pin 30 on your relay.
Old Dec 21, 2019 | 05:19 PM
  #48
almostakeeper
#30, the red/black wire at the relay. Am I splicing into that wire, bypassing it.
With my tester stuck inside the backside of the male connector for #30 it lights up when I hit the start button.
By putting a hot wire there wouldn't that cause the starter to continuously engage.
Just read up on an article from 2012, the dreaded click. I'll dig in to it tomorrow.
Old Dec 21, 2019 | 05:44 PM
  #49
texashillcountry
Dirt don't hurt
Just because it lights up doesn't mean you are getting full voltage.
In every connection in your harness you loose just a bit of voltage and it's worse if the connectors are corroded.
What the fused wire does is bypass the harness and apply full battery voltage to the starter when you hit the start button.
Old Dec 21, 2019 | 06:05 PM
  #50
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Another idea is to run the wire from pin 30 on the relay to the silver stud on the main breaker, that is how it was done on the old Softails. A nice fat current supply to actuate the solenoid.
The old Softails did not fuse this wire, but a fused wire (as THC suggests) is a good practice, remember to have the fuse close to the power source, be it battery or breaker.
