Clutch hub question
Old Jan 12, 2020 | 06:59 AM
Yankee Dog's Avatar
Yankee Dog
Johnjz knows his chit. Send him a PM. Don't see him post much in the evo section any more. Anyways, he provides good info, straight to the point. Tells it like it is. YD
Old Jan 12, 2020 | 08:51 AM
Racepres's Avatar
Racepres
Originally Posted by Scootertrash60
I don't remember seeing one of those in my 85 Low Rider. Hmmmm.....
What brand is the clutch hub?
That "support Washer"
is an afterthought ...and certainly must be a Tight fit as it is intended to keep the Hub from Splitting!!!!!
Old Jan 14, 2020 | 06:53 PM
Scootertrash60's Avatar
Scootertrash60
OK, I got it now!
Mine didn't have one. Until I installed a Jim's Titanium one a decade or two ago once I discovered they made one......
Old Jan 14, 2020 | 08:05 PM
Racepres's Avatar
Racepres
OK, I got it now!
Yes... the Band Aide, Washer is an Aftermarket item... far as i know the MoCo did not offer one... but I am far from expert on those years!!!
Truly I am very disappointed in that particular Design... there is two of the miserable "things" here... one on a project '86 FXWG, and one on the Eldest sons '86 Heritage Softail!!!
I much prefer the Shovelhead design personally... or...of course, the splined shaft and hub!!!!
Old Jan 15, 2020 | 05:22 AM
pjb's Avatar
pjb
Post some pictures of your 86 FXWG project.
Old Jan 15, 2020 | 05:54 AM
98hotrodfatboy's Avatar
98hotrodfatboy
So your saying that the spacer is similar to the ram jet that was used in the older seventies clutches as an after market fix for clutch basket movement?
Old Jan 15, 2020 | 09:07 AM
Racepres's Avatar
Racepres
OK... after we dig the darn thing out again!!!! Sometimes I wish we would Not have drug that darn thing home!!!!!
Well... sort of... The Ramm Jet retainer is a really good idea, and well executed...IMO
the support washer??? IDK... it seems an Afterthought... again a real Band-Aide... seems If [big word] If the MoCo offered a Steel Hub [ie Shovelhead hub] the darn thing would not have become a Problem.. that and deciding to try to "drive" off that puny little Key!!!!! On a Shovel...the key don't do squat [If again IF the Fit is good, hub to shaft] I have run many miles on a hub with No Key... driving off the taper, as is supposed to be... like a Snowmobile Clutch... the Taper does the Driving... No Key...
Anyway... rambling on a bit more.. The support "washer" seems to hold the puny aluminum Hub sleeve together.. and I'm gonna use them!!! I will be using bearing mount Loctite on mine... just cause I do Not want it escaping and moving around in there!!!
Old Jan 16, 2020 | 05:26 AM
glidein wide's Avatar
glidein wide
Hub is a Barnett, all assembled, test ridin, no vibration,
washer pressed snug, no more oil drips for a little while.
daven9113
EVO
15
Jul 7, 2021 10:50 AM
keith_lancaster
Jan 22, 2014 08:33 AM
1sttinker
Jan 20, 2012 08:21 PM
tgaetto
Mar 1, 2009 01:52 PM
guido4198
EVO
18
Jan 4, 2009 10:43 AM
