Cams
Old Feb 4, 2020 | 08:57 AM
TedMan's Avatar
TedMan
OK, just got some updated info from the owner. This 1996 FLSTN has an SE-3 cam in it, not SE-1. It does have the SE AC and Ignition Module, and also has a Thunderslide Jet Kit installed in the CV. I'm actually happier that it has the SE-3 instead of the SE-1. I've seen a lot of back and forth on the Thunderslide Jet kit. Guess I'll see how it goes. Still thinking I should change the lifters.......
Old Feb 4, 2020 | 09:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is no way of knowing what lifters are in the engine, but it originally came with a lifter that had some problems with the bearings inside the roller, they were upgraded to address this issue, and that is what is currently available.
I suggest that the lifters be replaced either with new OEM lifters, S&S,or Johnson Hylift units.
Avoid no name lifters (fleabay) like the plague...
I also suggest that you stick with the non adjustable pushrods.
Old Feb 4, 2020 | 10:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
More different information, se3 is a pretty good cam down low you'll like that actually. However I would try to find the dealer that the previous owner had the work done at and see if they can pull up any invoice regarding the install and possible lifter replacement. I don't know of anybody that doesn't replace lifters when they replace a cam especially if they went in and did the cam bearing as well. like I said earlier if you don't have issues I wouldn't get too excited about it and get pumped up on what you're reading when everything's already been taken care of. Try to locate the invoice..
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Old Feb 4, 2020 | 12:28 PM
TedMan's Avatar
TedMan
Thanks again everyone for solid advice. I know that the lifters were not swapped out when they did the cam and bearing, nor the pushrods, as the work was done with only about 3k miles on the clock. I think I am inclined to install new lifters for peace of mind. I just need to figure out the pushrods. I don't like the idea of taking the rocker covers off unless I need to. That's why I am interested in the quickie style pushrods.
Old Feb 4, 2020 | 01:07 PM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by TedMan
I understand these comments, but I was under the impression that there were service bulletins and recommendations to at least check if not change lifters by 25,000 miles.
People talk about this service bulletin, but I have yet to see it. I've never even seen a factory service manual mention it.
I don't know of anybody that doesn't replace lifters when they replace a cam especially if they went in and did the cam bearing as well ...
I guess I'm the odd ball. I changed my cam and cam bearing but didn't change the lifters. 98,000+ miles and still running.
Hell, I have 143,000+ miles on the Twin Cam with the stock lifters (stock cam).
nickybandy
Mar 1, 2021 12:36 PM
jlb0038
Jul 6, 2011 08:38 AM
jlb0038
Jul 3, 2010 02:55 PM
fj4069
Exhaust System Topics
Mar 17, 2008 07:10 AM
darkdyna06
Feb 24, 2008 11:35 PM
