Wearing down my last good nerve
Old Feb 12, 2020 | 08:34 PM
almostakeeper's Avatar
almostakeeper
Default Wearing down my last good nerve
OK, so I reinstalled the oil pump cover with a new gasket, put oil back in her, a bit in the jugs with the plugs out to crank the engine to be certain the oil pump light goes out. Hit the starter, Nothing. I'm like WTF, I already did the extra fused wire from the relay to the silver stud and it cranked plenty of times.
Hit the button a bunch more times, pulling in the clutch, making sure it's in neutral, nothing.
Called it a *****, hit the button and it worked. Took about 5 seconds cranking for the oil light to go out initially, and afterwards about 2 to 3 seconds.
My question, I'm going to put a second starter button on the solenoid. Is one brand better then the other. Is this something others have done.
Old Feb 12, 2020 | 10:24 PM
daven9113's Avatar
daven9113
No one brand is probably better. They are pretty close in price. I put one on and use it for most of my starts. No problem, and works every time.
Old Feb 13, 2020 | 06:01 AM
misfitJason's Avatar
misfitJason
There is a difference between the cheaper ones and the more expensive ones. I at one time had one that was a drag specialties one that the tolerances were too tight and it wouldn't actuate right.
Moral of the story is buy a nicer one and it will work better. Like the spyke one
Old Feb 13, 2020 | 06:03 AM
Kawickrice's Avatar
Kawickrice
I guess she has a name now. *****. I like it
Old Feb 13, 2020 | 09:34 AM
GBHH's Avatar
GBHH
She responded well to that.
Old Feb 13, 2020 | 10:09 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Extra fused wire....extra?
The silver stud on what?
Old Feb 13, 2020 | 06:54 PM
almostakeeper
This is your advice on "Electrical Headscratcher"
The wire to the #30 terminal on the starter relay is a hot wire, and when wired per the wiring diagram for a `95, it will be powered whenever the ignition switch is on (this is the high current circuit in the relay)...
The wire going to terminal 86 is the wire that is energized when the start button is pressed (this is the low current circuit of the relay).
A cleaner install would be to run
the wire to the silver stud of the main breaker, the less connections you have at a battery terminal the better.
Old Feb 14, 2020 | 09:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
You said extra wire, which is confusing...as there should only be one wire...
Old Feb 14, 2020 | 07:46 PM
almostakeeper
This is part of the conversation on the fused wire I ran.
(Another idea is to run the wire from pin 30 on the relay to the silver stud on the main breaker, that is how it was done on the old Softails. A nice fat current supply to actuate the solenoid.
The old Softails did not fuse this wire, but a fused wire (as THC suggests) is a good practice, remember to have the fuse close to the power source, be it battery or breaker)
I went ahead and ordered a 2nd push button starter for the solenoid. With either the on/off switch or the start switch on the handlebars not being reliable, will the new push button bypass both of those or just the start switch.
Old Feb 14, 2020 | 07:53 PM
carlgrover's Avatar
carlgrover
And here I thought I was the only one who called his bike a *****.
carl
